  3. Save multiple values versus frequency using spectremdl for...
  • Subscribers 136
  • Views 2116
Save multiple values versus frequency using spectremdl for spectre version 2016
GM202510215619
GM202510215619 10 months ago
I have this simple mdl code:
alias measurement ACplot{
run AC
export real ac_db  = db(V(Vout))     // Magnitude in dB
export real ac_ph  = r2d(ph(V(Vout)))// Phase in radians
run ACplot()
I don't understand why it only outputs one value for ac_db and ac_ph
Is there a way to save all values versus frequencies in these two exported outputs?
Thank you very much for answering.
    Andrew Beckett 10 months ago
    Measurements are typically scalar measurements (you can also output arrays in some cases), so to do this you'd need to write a formatted report instead. This should do the job:
      input string reportFile
      run AC
      print fmt("%-15s %-15s %-15s\n","freq","ac_db","ac_ph") to=reportFile
      print fmt("%-15.12g %-15.12V %-15.12V\n",xval(ac_db),ac_db,ac_ph) addto=reportFile
    run ACplot(reportFile="ACplot.rpt")
    The output file would then be in the file ACplot.rpt and would look like this:
    freq            ac_db           ac_ph
    1               -218.01580272   89.9999998193
    1.04712854805   -217.61580272   89.9999998108
    1.09647819614   -217.21580272   89.9999998018
    1.1481536215    -216.81580272   89.9999997925
    1.20226443462   -216.41580272   89.9999997827
    1.25892541179   -216.01580272   89.9999997725
    1.31825673856   -215.61580272   89.9999997618
    1.3803842646    -215.21580272   89.9999997505
    1.44543977075   -214.81580272   89.9999997388
    1.51356124844   -214.41580272   89.9999997265
    1.58489319246   -214.01580272   89.9999997136
    1.65958690744   -213.61580272   89.9999997001
    1.73780082875   -213.21580272   89.9999996859
    1.81970085861   -212.81580272   89.9999996711
    1.90546071796   -212.41580272   89.9999996556
    1.99526231497   -212.01580272   89.9999996394
    2.08929613085   -211.61580272   89.9999996224
    2.18776162395   -211.21580272   89.9999996046
    2.29086765277   -210.81580272   89.999999586
    2.39883291902   -210.41580272   89.9999995665
    2.51188643151   -210.01580272   89.9999995461
    2.6302679919    -209.61580272   89.9999995247
    2.75422870334   -209.21580272   89.9999995023
    and so on...
  • GM202510215619
    GM202510215619 10 months ago in reply to Andrew Beckett
    Thank you very much.
