  3. Graph window size in VIVA using OCEAN
  • Subscribers 136
  • Views 1902
msharma
msharma 10 months ago
I am plotting signals in multiple VIVA windows using the Ocean function awvPlotWaveform(). In the plot window, there are two columns: the left column containing the signal names and the right column  containing the plotted graphs. The graphing window size  depends on the length of signal names.  If the signal names are short, the left column is short and the right graph column is long (in the x-axis). I would like to have a consistent size of the graphing part of the plot window. How can I control the size of the graphing window in using OCEAN?
| SigName |  |            **                          |
|.                |. |        * *    (Graph plot)      |
|<---------->|.  |___*________________ |
    Andrew Beckett 10 months ago +1
    You can use the awvSetLegendWidth function to do this. Andrew
  • msharma
    msharma 10 months ago in reply to Andrew Beckett
    Thanks. The awvSetLegendWidth function worked.
