  3. ADE assembler: How to change packed probe limit for the...
  • Subscribers 136
  • Views 2658
ADE assembler: How to change packed probe limit for the AMS simulator (xcelium) ?
MC20250412421
MC20250412421 10 months ago
Hello everyone !
I am stuck at a rather annoying problem. I have created a simple system verilog cellview with the following code that is just a register that samples the input signal:
`define WIDTH 5000
module TestSV (
    input logic clk,
    input logic rst,
    input logic [`WIDTH-1:0] in_bus,
    output logic [`WIDTH-1:0] out_bus
logic [`WIDTH-1:0] out_bus_n;    // next state
logic [`WIDTH-1:0] out_bus_p;    // present state
// assign outputs
assign out_bus = out_bus_p;
// output dff's
always_ff @(posedge clk or posedge rst) begin
    if (rst) begin
        out_bus_p <= '0;
    end else begin
        out_bus_p <= out_bus_n;
    end
end
always_comb begin
    out_bus_n = in_bus;
end
endmodule
I then connected this module in a schematic view with simple analog components like vdc and vpulse and used bus syntax to connect analog sources to the input bus of the sv module.
I then went into ADE assembler, set AMS as the simulator, set connect rules to use UCM (universal connect modules) as the default.
When I simulate my circuit with WIDTH = 4000 the simulation works perfectly as expected, when I simulate with WIDTH=5000, it doesn't work anymore and I get the following message for every single bit of my output bus:
    xcelium> probe -create -emptyok -database ams_database {TestSV_TB.out_bus[6]} xmsim: *W,LMTMSG: packed array at "TestSV_TB.out_bus" of 5000 elements exceeds limit of 4096 - not probed Use 'probe -create -packed 5000' to adjust limit. Created probe 4994
I went to the support and found this page on support.cadence.com which is all fine and well but I don't see how to fix the issue within ADE assembler.
What I tried was right clicking on the ADE test, then I went  "Options -> AMS Simulator -> Miscellaneous -> Add User Tcl files" and added a file with set probe_packed_limit 10000 in it and it didn't fix anything. And obviously I would want to follow the hint xcelium gave me which is using probe -create -packed 5000 but this too I do not know how to add within ADE assembler. Any way to do that in ADE ?
Thanks in advance for your help !
Mike
    Andrew Beckett 10 months ago +1
    Mike, Create a tcl file that looks like this: set probe_packed_limit 10000 source probe.tcl Then add the user tcl file (as you mentioned), but also uncheck the Enable the Tcl file generated by ADE…
    Mike,
    source probe.tcl
    Then add the user tcl file (as you mentioned), but also uncheck the Enable the Tcl file generated by ADE just above it on the Misc tab. The trouble is otherwise it includes the ADE generated probe.tcl file first, and it's too late to alter the probe_packed_limit. This way you set the limit and then include the probe file that would have been passed to xrun yourself, so you are changing the limit before all the probes.
    It seems to work for me, at least!
  • MC20250412421
    MC20250412421 10 months ago in reply to Andrew Beckett
    It works ! As always, you are spot on Andrew !
    Thank you so much for all your help
