  3. Noise file for Isource - Transient Simulation is NOT No...
  • Subscribers 136
  • Views 3044
Noise file for Isource - Transient Simulation is NOT Noisy
PN202601231518
PN202601231518 9 months ago
Hello.
Spectre (R) Circuit Simulator
Version 25.1.0.054 64bit -- 16 Jul 2025
I am running a transient simulation with an Isource and an include file of frequency/noise pairs (A^2/Hz):
1000 2.941254701486845e-10
1258.925411794167 2.696841722180617e-10
1584.893192461114 2.4836432387389e-10
1995.26231496888 2.29843362353326e-10
The source will be included in a circuit of a transient noise simulation.
The simulation runs sucessfully and "sees" the noise file...but the simulation of the current has no noise; flat DC.
Please can someone help ?
***** Netlist *****
// Cell name: noise
// View name: schematic
V1v0 (v_and_i 0) vsource dc=1 type=dc
Inoise (v_and_i 0) isource dc=0 type=dc m=1  noisefile="q" isnoisy=no noisetype=noisecurrent noiseinterp=linear
    iabstol=1e-12 temp=27 tnom=27 scalem=1.0 scale=1.0 gmin=1e-12 rforce=1 \
    sensfile="../psf/sens.output" checklimitdest=sqldb
tran tran stop=10u errpreset=conservative noisefmax=200e6 noisefmin=1000 \
    noiseseed=1 write="spectre.ic" writefinal="spectre.fc" annotate=status \
    save=all maxiters=5
    Andrew Beckett 9 months ago
    Two issues:
    1. You have the current source in parallel with an ideal voltage source. The voltage at the output will always be 1V. The current could vary though
    2. You have the noise source (Inoise) with isnoisy=no - so it won't produce any noise anyway.
    If you simply change to isnoisy=yes and then plot the current through the voltage source, you'll see it's noisy.
    Or you could change the netlist to:
    rload1 (v_and_i 0) resistor r=1k isnoisy=no
    Inoise (v_and_i 0) isource dc=1m type=dc m=1 noisefile="forum202q" isnoisy=yes noisetype=noisecurrent noiseinterp=linear
    Then you'll see the voltage varying.
  • PN202601231518
    PN202601231518 9 months ago in reply to Andrew Beckett
    Thanks.
    I am after the noise current so of course the DC voltage is fine, I just probe noise current.
    I selected "Generate noise=yes"
    I changed my noise file to a single line:
    1e6 1e-6
    Still the same result...nothing.
    I changed the voltage source to a noiseless  resistor and I now get random voltage noise.
    So, I think, "Generate noise" for the Isource just generates random noise ??
    From the above single line noise file I would expect a single tone at 1MHz.
    Regards
    Phil
  • PN202601231518
    PN202601231518 9 months ago in reply to PN202601231518
    Correction.."generate noise=yes" always generates random noise....I can never get a single tone from my noise file.
    Andrew Beckett 9 months ago in reply to PN202601231518
    If you looked at the current, then you would see it noisy (as I said, the voltage can't change if it's an ideal voltage source connected to the node).
    The whole point of what it has to do is to translate a frequency-domain description of wide-band noise behaviour into something that generates random noise with the same spectrum as described in the noise file (within reason). Expecting that to produce a single tone is not realistic - this is not what the noise file is for.
  • PN202601231518
    "The whole point of what it has to do is to translate a frequency-domain description of wide-band noise behaviour into something that generates random noise with the same spectrum as described in the noise file"
    That is the information I was missing; I could not find any description of this mode of operation in the documentation for the Isource.
    Thanks.
