  3. Syntax errors when utilising idt() in bsource
  • Subscribers 136
  • Views 3272
GT20260122746
GT20260122746 9 months ago
I am trying to model a behavioural current source in the spectre netlist, and I am running into some issues, as I cannot find much documentation on the problem.
From my understanding, I should be able to use idt() functions in these sources and (I think) the syntax is:
idt(x a assert)
Where a is the intiial condition and assert is the conditional expression to assert this condition.
I model my source like:
parameters var1 = 100
dummyR (N1 N2) resistor r = 10
TestSource (N2 0) bsource i = idt(v(N1) > 1 && v(N1) < var1 ? (2*i("dummyR:1")) : 0) 0 v(N1) < 1)
Which, if I understand correctly will integrate the expression (2*i("dummyR:1")) if the two conditions v(N1) > 1 && v(N1) < var1 are true, and will assert to 0 when v(N1) < 1.
Worth noting, this is connected to some sources at N1. I am porting this from an LTSpice model, which works as expected.
The above gives me errors:
Error: Illegal parameter name `0' specified, please do not use `number name' as the parameter name.
Error: Cannot run the simulation because syntax error `Unexpected operator "<". Expected end of file or end of line' was encountered at line 85, column 104. Correct the syntax error and rerun the simulation.
Have I misunderstoof the syntax? Or have I misunderstood the implementaion of idt() in the spectre enviroment? I saw in "Virtuoso Spectre Circuit Simulator User Guide" page 87, that bsource i should take a generic_expr which:
A simple expression that may contain idt () or ddt() as well.
Any help appreciated.
Thanks.
  • GT20260122746
    As an update, I found the correct syntax required:
    idt(x, a, assert)
    so:
    TestSource (N2 0) bsource i = idt(v(N1) > 1 && v(N1) < var1 ? (2*i("dummyR:1")) : 0, 0, v(N1) < 1)
    And it now doesn't throw the errors, but when I got to simulate I get:
     ERROR (SFE-2326): "..." 83: The 3 argument of function `idt' does not support behavioral expressions.
    Which i'm guessing is meaning it doesn't like the < in the assert? But then I think I am not understanding how to translate this from LTSpice, as this mechanism works there.
    Andrew Beckett 9 months ago in reply to GT20260122746
    You're probably better off using a VerilogA model if you need something more complicated.
    Otherwise, contact customer support so that we can look at it in more detail.
  • GT20260122746
    GT20260122746 9 months ago in reply to Andrew Beckett
    Thanks Andrew. If I am understanding correclty you are suggesting I implement the behavioural source as a VerilogA model, and then implement it in the Spectre netlist. This seems sensible from my brief reading this afternoon, but I do have one question:
    Is there a method of accessing the branch currents/node voltages of the higher level from within the VerilogA model? For example, in my initial model I would like the output of behavioural source to be dependent on the current through the dummyR, which would be defined in the main circuit in Spectre netlist. Although in the example they are in series, I can think of examples where they would not be.
    Or is the solution to create dummy nodes within the VerilogA model and connect these up to the relevant points in the main Spectre netlist to monitor current/votlages?
    I think you'd have to have connections to the VerilogA model to probe voltages and currents you wish to monitor. Monitoring higher level objects is not possible (as far as I know).
