  3. case Statement in range type spec
  • Subscribers 136
  • Views 1723
Kevin T Buck
Kevin T Buck 9 months ago
I'm trying to create a case statement for an output specification in maestro. An example of the first few outputs is the following:
"range (case(VAR(""ical_sel"") (""0"" 0.02) (t 0))) (case(VAR(""ical_sel"") (""0"" 0.03) (t 0.001)))"
"range (case(VAR(""ical_sel"") (""1"" 0.02) (t 0))) (case(VAR(""ical_sel"") (""1"" 0.03) (t 0.001)))"
"range (case(VAR(""ical_sel"") (""2"" 0.02) (t 0))) (case(VAR(""ical_sel"") (""2"" 0.03) (t 0.001)))"
"range (case(VAR(""ical_sel"") (""3"" 0.02) (t 0))) (case(VAR(""ical_sel"") (""3"" 0.03) (t 0.001)))"
I've tried using with and without quotes for the variable type and also tried using ical_sel directly without wrapping it in the VAR operator (two sets of double quotes are shown in the text file output, in the maestro view there is only one double quote).
The ical_sel variable in the design variable list looks like this: {From/To}Linear:0:1:3{From/To}.
This is an ams simulation, I've used this type of expression in the past using spectre without any problem and from the documentation and testing in the CIW it seems like the case statement should work as expected but the output is always evaluated with the (t 0) or (t 0.001) case.
Tool version is IC23.1-64b.ISR16.19.
    Andrew Beckett 9 months ago
    I'm not sure where these strings are being created. I entered a similar range specification on an output and used the case function. I then exported to CSV (that was my guess as to where this "range" syntax was coming from):
    range (case(round(VAR("ical_sel")) (2 1.9) (t 0.0))) (case(round(VAR("ical_sel")) (2 2.1) (t 0.001))),
    I don't need any escaped quotation marks, and because the VAR() function is returning a number (a float) I converted it to an integer to do the comparison in the case branches. You should not really use case with the target values being floating point as small rounding errors could lead to a non-match. So in this case it worked fine (note, I set the limits a little different to suit my testcase; in my example I just had a voltage source with a voltage of ical_sel and only the point with ical_sel=2 passed.
  • Kevin T Buck
    Kevin T Buck 9 months ago in reply to Andrew Beckett
    Thanks for the reply. I did copy/paste from an exported csv (my corporate security policy prevents uploading screenshots to Cadence, I should probably ask them to white list this site). The second set of quotes popped up because I was trying to see if the tool was interpreting the design variable input as a string and causing the case evaluation to fail (so inside of the case statement it said VAR("ical_sel") == "0" ...). My initial statement looked exactly like yours without the round() function wrapping the variable. I was attempting to use case because I saw the following article:
    https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1O0V000006AjVQUA0&pageName=ArticleContent
    In any case I was able to make this work using an if statement rather than a case statement. The syntax I used in the working solution was:
    range (if((VAR("ical_sel") == 0) 0.02 0) if((VAR("ical_sel") == 0) 0.03 0.001))
    Thanks again.
