  3. how to input values with units/dimensions like 1 Ohm or...
  • Subscribers 136
  • Views 376
how to input values with units/dimensions like 1 Ohm or 1V in calculator
an wx
an wx 9 months ago
Hi all, I'm wondering is there a way to input a value with physical units (like, 1 Ohm or 1 Volt) in calculator. For example, I've got a voltage waveform (let's say, VT("/net1")), and I want to see how much current it yield on a 1kOhm resistor. I can simply write VT("/net1")/1E3 to get the value, but it still has the dimension of voltage instead of current as desired. Is there a way to input a unit?
