  3. Inconsistent evaluation/plotting of phase-correction expressions...
  • Subscribers 137
  • Views 1761
Inconsistent evaluation/plotting of phase-correction expressions in ADE Assembler vs. Calculator (IC23.1-64b.43)
baltaci
baltaci 9 months ago
I am observing inconsistent behavior between the Virtuoso Calculator and ADE Assembler result evaluation when trying to unwrap the phase from an STB analysis so that it starts at +180° and can be used conveniently for phase-margin and gain-margin calculations.
Goal
From an STB analysis I obtain loop gain phase:
phase0 = phase(getData("loopGain" ?result "stb"))
Because the phase may start at −180° (or 180° ± n·360°), I compute a correction term so the low-frequency phase starts at +180° and downstream calculations (e.g., cross() for phase margin) are straightforward.
Solution 0 (works numerically, but cannot be plotted from Results)
phase_correction = (360 * round(((180 - value(phase0 firstVal(phase0))) / 360)))
phase = (phase0 + phase_correction)
Observed behavior
  • ADE Assembler recognizes phase as a waveform (wave icon shown in Outputs/Results).
  • Downstream expressions using this phase (e.g., cross() for phase margin) evaluate correctly.
  • However, double-clicking the waveform to plot fails with:
*Error* ("round" 0 t nil ("*Error* round: argument #1 should be a number (type template = "n")" srrWave:0x49863400))
ERROR (ADE-1057): Could not evaluate expression
        Expression:'(360 * round(((180 - value(phase0 firstVal(phase0))) / 360)))'
     because of the following error(s)
     Ensure that the definition of the expression is correct.
*Error* ("round" 0 t nil ("*Error* round: argument #1 should be a number (type template = "n")" srrWave:0x498634c0))
*Error* ("plus" 0 t nil ("*Error* plus: can't handle (srrWave:0x49863420 + unbound)"))
        Expression:'(phase0 + phase_correction)'
So the expression behaves as:
  • Valid for numerical post-processing
  • Invalid for plotting
Solution 1 (Calculator plots OK, but ADE output gives eval error)
As a workaround I modified the correction:
phase_correction1 = (360 * round(((180 - ymax(value(phase0 firstVal(phase0)))) / 360)))
phase1 = (phase0 + phase_correction1)
Observed behavior
  • In the Virtuoso Calculator, plotting phase1 works correctly.
  • When defined as an ADE Assembler output, it results in eval err after simulation.
So this case behaves as:
  • Valid in Calculator
  • Invalid in ADE output evaluation
Confusion / Question
These two cases appear inconsistent:
Expression Calculator ADE numerical eval ADE plotting
Solution 0 OK OK Fails
Solution 1 OK Fails N/A
This makes it difficult to determine:
  • what data types (number vs. wave) are actually expected by round(), value(), ymax(), etc.
  • why ADE can use a waveform expression for further calculations but cannot plot it
  • what the recommended method is to unwrap STB phase to start at +180° in a way that is:
    • numerically robust
    • plottable
    • ADE-compatible
Questions
  1. Is this inconsistent behavior between Calculator, ADE evaluation, and ADE plotting expected?
  2. Is there a Cadence-recommended method to unwrap STB phase to +180°?
  3. Could this indicate a bug in ADE expression evaluation or plotting?
Environment
Cadence IC version: IC23.1-64b.43
Analysis: STB in ADE Assembler
Any clarification or recommended best practice would be greatly appreciated.
Thank you.
Can
  • Frank Wiedmann
    Frank Wiedmann 9 months ago
    I suggest that you try
    phase0 = phase(-getData("loopGain" ?result "stb")) + 180
    This is much simpler and might avoid all these problems in the first place. You can find some more background about this loop gain definition at https://designers-guide.org/forum/YaBB.pl?num=1124688329
    Regarding your problems with defining an expression that works in all cases, a look at https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1O0V000007MkO7UAK and https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1O3w000009F4LBEA0 might help.
