  3. Does Spectre native syntax support arrayed instances (bus...
  • Subscribers 136
  • Views 2702
Does Spectre native syntax support arrayed instances (bus notation)?
GX202407164559
GX202407164559 9 months ago
I'm running into an issue when trying to use arrayed/bused instances in Spectre native syntax (simulator lang=spectre).
What I tried
I have a subcircuit (let's call it MY_CELL) with several ports, and I need to instantiate 256 copies of it with bused connections. I tried the following in native Spectre syntax:
// Attempt 1: angle brackets (SPICE-style)
XI0<0:255> ( A<0:255> B C<0:255> D ) MY_CELL
// → ERROR (SFE-874): Unexpected operator "<"
// Attempt 2: square brackets
XI0[0:255] ( A[0:255] B C[0:255] D ) MY_CELL
// → ERROR (SFE-874): Unexpected open square bracket "["
Both attempts produce syntax errors under simulator lang=spectre.
Current workaround
I'm currently switching to SPICE mode inline for the arrayed instance, then switching back:
simulator lang=spice
XI0<0:255> A<0:255> B C<0:255> D MY_CELL
This compiles and runs, but it feels like a workaround rather than a proper solution.
My questions
  1. Is it confirmed that Spectre native syntax does not support arrayed/bused instances at all? I couldn't find a definitive statement in the documentation (SPECTRE User Guide or Reference). If it is supported, what is the correct syntax?
  2. Performance: expanded vs. bused instantiation. If native Spectre doesn't support bus notation, the alternative is to write out all 256 instances explicitly (unrolled, Virtuoso is using \< \>), e.g.:
XI0_0 ( A_0 B C_0 D ) MY_CELL
XI0_1 ( A_1 B C_1 D ) MY_CELL
XI0_255 ( A_255 B C_255 D ) MY_CELL
            Compared to the SPICE-mode <0:255> bus notation, is there any difference in simulation performance (parsing time, memory usage, or solve time)? Or does the simulator internally expand the bus notation into individual instances anyway, making them equivalent?
        3. Best practice recommendation. For large designs requiring hundreds of repeated instances, what is the recommended approach in Spectre — use the inline simulator lang=spice switch, write a script to generate the unrolled netlist, or something else?
Any insights would be greatly appreciated. Thanks in advance!
Environment:
  • Spectre version: @(#)$CDS: spectre  version 23.1.0 64bit 04/15/2024 22:19 (csvcm36c-3) $
  • OS: RHEL 9.6
    Andrew Beckett 9 months ago
    Spectre does not support iterated instances or buses in its native language.
    When you use that syntax in the SPICE mode, it's not an iterated instance or a bus - it's just an instance name or net name with unusual characters in. There's a single instance of MY_CELL only. So there's no performance benefit one way or another because it's not a bus or an iterated instance here...
    If you're not using ADE, then the solution is to build the expanded netlist somehow.
  • GX202407164559
    GX202407164559 9 months ago in reply to Andrew Beckett
    Do you mean there is only one MY_CELL whose name is "XI0<0:255>"?
    I see, so the only solution will unroll it via script/manually/ADE.
    E.g.
    Thank you for your reply.
    Andrew Beckett 9 months ago in reply to GX202407164559
    Yes, that's right.
  • GX202407164559
    Would you remind me if there is Spectre Netlist Language Standard file?
    I found one chapter on "Spectre ® Classic Simulator, Spectre APS, Spectre X, Spectre XPS, Spectre FMC Analysis, and Legato Reliability Solution User Guide" Section Spectre Netlist. Is that all?
    Best,
    GX
    I found one chapter on "Spectre Registered Classic Simulator, Spectre APS, Spectre X, Spectre XPS, Spectre FMC Analysis, and Legato Reliability Solution User Guide" Section Spectre Netlist. Is that all?
    I'm not sure what you mean by Spectre Netlist Language Standard file. The Spectre user guide that you found has a chapter covering the netlist syntax (which in general is simple and pretty regular compared with SPICE), and the subsequent chapter Parameter Specification and Modeling Features builds upon this. There is a sample netlist also included in the Getting Started with the Spectre Circuit Simulator chapter which outlines the key elements in the netlist.
