  3. how to change the axis name with assembler expressions
  • Views 1503
Mooh
Mooh 9 months ago
For example, I have this signal s22, and I want to change the X axis to be named NF and the Y axis  to be Freq_of_blocker
I tried this, but it didn't work
    Andrew Beckett 8 months ago
    This approach won't work as the expectation is that the function returns a number or a waveform; if you had done a sweep (and this had worked) then you could have ended up with lots of separate plots - also, the expression evaluation in the background would fail and it wouldn't know whether this is a waveform or a scalar.
    The code below can be used to give you a calculator function that allows you to update the x and/or y axis names. Not sure that plotting the y axis name as "NF" (Noise Figure) makes sense when it's s22, but presumably it makes sense to you!
    /* abSetAxisNames.il
    Author     A.D.Beckett
    Language   SKILL
    Date       Feb 15, 2026
    Modified
    By
    Set either the x-axis name, the y-axis name, or both for a signal.
    abSetAxisNames(VT("/out") ?xname "something" ?yname "else")
    Both keyword arguments are optional; if omitted, that axis name is
    unchanged.
    To use in the calculator (from IC617) use the fx button in the Function
    Panel or the + button in the Expression Build to register the function.
    SCCS Info: @(#) abSetAxisNames.il 02/15/26.10:30:02 1.1
    *   (abSetAxisNames wave [?xname "new x"] [?yname "new y"])    *
    *    Update the x-axis name (label) and/or the y-axis name.    *
    (defun abSetAxisNames (wave @key xname yname)
      (when (symbolp xname)
        (setq xname (symbolToString xname)))
      (when (symbolp yname)
        (setq yname (symbolToString yname)))
      (cond
        ((drIsWaveform wave)
         (when xname
           (putpropq (drGetWaveformXVec wave) xname name))
         (when yname
           (putpropq (drGetWaveformYVec wave) yname name))
         wave
        ((famIsFamily wave)
         (famMap 'abSetAxisNames wave ?xname xname ?yname yname)
        (t wave)
    ;;;;;;;;;;;;;;;;;;;;;;;;;; GUI builder information ;;;;;;;;;;;;;;;;;;;;;;;;;;;
    ocnmRegGUIBuilder(
     '(nil
      function abSetAxisNames
      name abSetAxisNames
      description "abSetAxisNames"
      category ("Custom Functions")
      analysis (nil
          general (nil
            args (wave xname yname )
              signals (nil
                    wave (nil
                          prompt "wave"
                          tooltip "wave"
              params(nil
                     xname (nil
                           prompt "X Name"
                           tooltip "X Axis Name"
                           guiRowHint 1
                           type string
                           required nil
                           keyed t
                     yname (nil
                           prompt "Y Name"
                           tooltip "Y Axis Name"
                           guiRowHint 1
                           type string
                           required nil
                           keyed t
            inputrange t
      outputs(result)
  • Mooh
    Mooh 8 months ago in reply to Andrew Beckett
    Thanks, Andrew, so much.
