  3. ADE Explorer: Disable Check for Analysis Specified
  • Subscribers 136
  • Views 1379
sgcad
sgcad 8 months ago
Hi all,
By default, ADE Explorer checks if there is an analysis specified through the GUI and throws an error if one attempts to run a simulation without any analysis specified in the GUI.
How can I disable this check? Usually I specify my analyses with a netlist include file, thus the simulation should run even without analysis specified in the GUI.
Thanks very much for your reply!
    Andrew Beckett 8 months ago
    See How to run Spectre static checks from ADE with no other analysis active (different reason, but same environment variable should do the trick).
  • sgcad
    sgcad 8 months ago in reply to Andrew Beckett
    ThumbsupThanks very much, Andrew, worked perfectly.
