  3. New ADE feature for statistical design variable definition...
  • Subscribers 136
  • Views 1918
New ADE feature for statistical design variable definition: Global vs local? Correlation?
StephanWeber
StephanWeber 8 months ago
today I found this nice feature in the MC setup window (last button), but I miss a bit to decide for global vs local variation. And how to define a correlation?
BTW, it would be good to get a template fill-out with onb click e.g. for standard normal variable.
I think if we define two variables they are independant, but building e.g. sum and looking the corr of this sum to the variables it will have some value, so basically a definition for correlated variables is possible. Just to have an example would be great.
Bye Stephan
    Andrew Beckett 8 months ago
    Stephan,
    It's not new. It's been there for probably 5 years (see How to vary design variables with statistical distribution to be used with Monte Carlo analysis). It only creates process variations - this is because for mismatch variations, you need to have a component or model within a subckt that reference the parameter with mismatch variation so that each instance has a local variation. See A simple method of applying mismatch to ideal components and Recommended Spectre Monte Carlo modeling methodology. Because of the need to define a subckt model (done in the article above with a sub-schematic), we've not added a UI to set up the mismatch variation because you can guarantee that otherwise people would try it, not see the variation, and then there would be a flood of requests...
    There is a way of creating correlations using constraints, but to be quite honest the best thing is to define your models that need variation so that they follow the methodology in the Don's document above (Recommended Spectre...) and then you can also define the statistics block - which can also have correlation coefficients - see "spectre -h montecarlo" - you can then define the process and mismatch variation (global and local, in other words) and any correlations too. Then include this in your simulation as a model file.
  • StephanWeber
    StephanWeber 8 months ago in reply to Andrew Beckett
    I agree, the scs-file way with statistics part is still a good approach.
    To mimic mismatch and correlation is not so difficult too:
    1. Create two variables (e.g. with mean=0, and stddev=1)
    2. Then built Y=X1*c + X2*sqrt(1-c*c)
    Y has now also stddev=1 and mean=0, but correlation c to X1=X.
    3. To model mismatch we need to inspect (Y-X), and its stdev is sqrt(2*(1-c)).
    If we now want e.g. 1% mismatch, we need to chose c=0.99995.
    This way you can e.g. model a bias generator for your testbench with two correlated outputs.
    Would be nice if Cadence can support this out-of-the box, e.g.as cell  in ahdlLib or analogLib or directly in ADE GUI (for pairs of variables, like you define the statistical variables as now, but then user can select two rows, and press RMB for Define correlation and mismatch).
