  3. get the difference between two wave forms after parametric...
  • Subscribers 136
  • Views 2323
get the difference between two wave forms after parametric sweep.
Svilen64
Svilen64 8 months ago
I have run a parametric sweep to get different delays of a clock signal and I created an expression that extracts the delay of the rising edge with respect to a reference depending on the parameter. Then I shifted that by one index count, index being swept. Now I want to take the difference between those two so I can plot the delay for each two consecutive values of the swept parameter . Can I do that without starting scripting in Skill or Ocean?
Svilen
    Andrew Beckett 8 months ago
    Svilen,
    Almost certainly this could be done with an expression using the eval type set to “sweeps”, but could you please share the expressions used and what you are sweeping too - it’s hard to be certain precisely what you are doing and I’d like to make sure that any specific suggestion I make has been tested and is close to what you actually need.
    Maybe also sharing a screenshot of the results you get in ADE and then showing which you want to get the difference between?
  • Svilen64
    Svilen64 8 months ago in reply to Andrew Beckett
    Thanks for replying.
    I did try to attach an image yesterday but it didn't allow me. So I had to describe it in words which I'll do again, hopefully in a better way.
    I am running a parametric sweep on a variable called "bits" which controls the delay of my clock. I am sweeping it over a list of non-uniform values, something like 0 1 3 7 15 31 etc. I have also created another variable ind (for index) that's uniform, 1 2 3 4 5 6 etc. It doesn't control anything in the circuit but I grouped it in a parametric set with the first one  just to have a uniform index to plot against.
    The output I monitor is VT("/out") and the reference with respect to which I want to plot is defined as expression ref = value(VT("/out") "bits" 0)
    I have defined family = VT("/out") for the family of plots from the sweep.
    Then I define the delay from the reference 2nd rising edge to the 2nd rising edges of any of the clocks in the family del=delay(ref 0.4 2 "rising" family 0.4 2 "rising")
    And just for the sake of it, I've also defined an expression for index=VAR("ind")
    All those are set as evalType sweeps.
    From the calculator I plot waveVsWave(?x index ?y del), also rshift(waveVsWave(?x index ?y del) 1). Now I have two plots for the delay and the delay shifted by one count of index with respect to each other. The idea was to take the difference between the two and thus have the delay between each two consecutive edges of my clock as I perform the sweep. But that difference returns 0.
    Since I couldn't upload an image here, I uploaded it to https://archive.org/details/sweep_20260226
    Regards
    Svilen
  • Svilen64
    I did try to attach an image yesterday but the system didn't allow me. A while back I also replied to you with the information you requested and also gave the URL to where I uploaded the image online and my reply was flagged as spam. So, I will again explain in words what I was doing and provide no visual material unfortunately. Which is sort of ridiculous not being able to do.
    I have a variable in my testbench called bits which controls the delay of a clock and I want to sweep that variable and get different delays. The sweep is over a list of values which are non-uniform, say 0 1 3 7 15 31 etc. I also created another variable ind (for index) which is uniform 1 2 3 4 5 6 etc. That variable doesn't control anything in the test bench but I grouped it in a parametric set with the first one, so they go together.
    The output I am interested in is VT("/out").
    I have defined my reference with respect to which I measure the delay as ref=value(VT("/out") "bits" 0)
    I have defined the family of clocks from the sweep as family=VT("/out")
    Then I define the delay from the rising edge of the ref to the rising edges of each clock in the family del=delay(ref 0.4 2 "rising family 0.4 2 "rising")
    Also defined index=VAR("ind")
    All those are evalType sweeps.
    Form the calculator I plot two things
    I can plot those and now I have two delay sets of points shifted with respect to each other by one index count. The idea being to take the difference and have the delay between each two consecutive edges of the clock, which ultimately I wanted to plot. However, the difference returns just 0.
    Regards
    Svilen
    Andrew Beckett 8 months ago in reply to Svilen64
    Svilen,
    Unfortunately there's a bug with the forum system that it intermittently disallows image updates (this affects me too). It's known and we hope that this will be fixed when we upgrade to the next version of the forum software provided by the vendor. The workaround of using an external site for images works, but external URLs are flagged as potential spam and have to be appealed, reviewed and the approved (which I did - so it's in the thread above).
    I'll look into your situation and see whether I can reproduce something similar. May not be until later today or tomorrow though...
  • Svilen64
    Thanks for unblocking that reply. I hope now with the image and my previous description it is more or less clear what I was trying to do.
    Svilen
