  3. $fscanf and $fget do not work when any portion of Verilog...
  • Subscribers 136
  • Views 1651
$fscanf and $fget do not work when any portion of Verilog-A file is encrypted
ConradJ
ConradJ 8 months ago
$fscanf and $fget appear to return empty strings if any portion of the Verilog-A file is encrypted, but work fine if the encrypted portion is removed.
This Verilog-A code reads in data from an external file and prints some information to the spectre log. The file example.txt contains the phrase "You should see this".
// VerilogA for VerilogA_Bug_Example, ReadFile, veriloga
`include "constants.vams"
`include "disciplines.vams"
module ReadFile;
parameter string file_location="/home/USER/example.txt";
integer myChanDesc;
string temp;
// pragma protect
// pragma protect begin
    analog function real doNothing;
        input x;
        real x;
        begin
            doNothing = x;
        end
    endfunction
// pragma protect end
analog begin
    @(initial_step) begin
        $strobe("!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!");
        myChanDesc = $fopen(file_location, "r");
        $strobe("Channel Descriptor: %d", myChanDesc);
        $strobe("Path: %s", $cds_get_resolved_path( myChanDesc ));
        $fgets(temp, myChanDesc);
        $strobe("First Line: %s", temp);
        $strobe("Non-zero if end-of-line: %d", $feof(myChanDesc));
    end
end
endmodule
The above code correctly returns the following when run in a transient simulation by Spectre APS:
Channel Descriptor: 2
Path: /home/jensenct/txt.txt
First Line: You should see this
Non-zero if end-of-line: 0
After running the below command to encrypt the "doNothing" function the below code is produced. (Note the encrypted blob was removed for security reasons).
/apps/cadence/SPECTRE231/tools.lnx86/bin/64bit/xmprotect -language vlog verilog.va
module ReadFile;
integer myChanDesc;
string temp;
//pragma protect begin_protected
//pragma protect encrypt_agent="NCPROTECT"
//pragma protect encrypt_agent_info="Encrypted using API"
//pragma protect key_keyowner=Cadence Design Systems.
//pragma protect key_keyname=prv(CDS_RSA_KEY_VER_2)
//pragma protect key_method=RSA
//pragma protect key_block
//pragma protect end_key_block
//pragma protect digest_block
//pragma protect end_digest_block
//pragma protect data_block
//pragma protect end_data_block
//pragma protect end_protected
analog begin
    end
end
endmodule
Which incorrectly returns the following when run using the same test bench:
Path: /home/USER/example.txt
First Line:
Running $ftell after trying to read several lines still returns 0. This issue also appears to impact $fscanf.
    Andrew Beckett 8 months ago +1
    I see this problem when using Spectre 23.1.0.802.isr17. However, if I use 24.1.0.513.isr13 or 25.1.0.274.isr6 (the latest versions of either SPECTRE24.1 or SPECTRE25.1) then it works (note, it's the spectre…
    I see this problem when using Spectre 23.1.0.802.isr17. However, if I use 24.1.0.513.isr13 or 25.1.0.274.isr6 (the latest versions of either SPECTRE24.1 or SPECTRE25.1) then it works (note, it's the spectre version that makes the difference, not the xmprotect version).
    I couldn't find precisely when this was fixed - there were some other fixes related to visibility of information in protected code so maybe this got fixed alongside those.
  • ConradJ
    ConradJ 8 months ago in reply to Andrew Beckett
    That fixed it! Thank you!
