  3. Specifying variable as a parametric sweep in ADE Explorer...
  • Subscribers 136
  • Views 1457
Specifying variable as a parametric sweep in ADE Explorer (when the parametric weep involves another variable)
msharma
msharma 8 months ago
I want t o sweep a variable varX through 5 values. The step size is constant, but the sweep is relative to another variable varY.
varX = varY + (-2:1:2)
What is the acceptable syntaxt to specify this sweep?
I tried
varX = (varY-2:1:varY+2)
but they gave an error by the simulator.
    Andrew Beckett 8 months ago
    Create an additional variable:
    varSweep = -2:1:2
    varX = varY + varSweep
    You can't put variables in the sweep definitions (partly because this could lead to a variable number of sweep points, which is not supported).
