  3. Problems with Virtuoso ADE Explorer
  • Subscribers 136
  • Views 2435
FZ20251125769
FZ20251125769 8 months ago
Hi!
I've been trying to run a simulation in ADE Explorer or ADE Assembler and I get this error every time:
Spectre (R) Circuit Simulator
Version 24.1.0.078 64bit -- 14 Sep 2024
Copyright (C) 1989-2024 Cadence Design Systems, Inc. All rights reserved worldwide. Cadence and Spectre are registered trademarks of Cadence Design Systems, Inc. All others are the property of their respective holders.
Includes RSA BSAFE(R) Cryptographic or Security Protocol Software from RSA Security, Inc.
User: fzapata   Host: cadence   HostID: E70A569B   PID: 4708
Memory  available: 23.4371 GB  physical: 24.4112 GB
Linux   : AlmaLinux release 8.10 (Cerulean Leopard)
CPU Type: AMD Ryzen 7 6800H with Radeon Graphics
        Socket: Processors [Frequency] (Hyperthreaded Processor)
        0:       0 [2221.5] (),  1 [1095.8] (),  2 [1992.9] (),  3 [1095.8] (),  4 [4442.4] ()
                 5 [1095.8] (),  6 [3344.5] (),  7 [1095.8] (),  8 [2301.2] (),  9 [1095.8] ()
                10 [3414.2] (), 11 [1095.8] (), 12 [1971.6] (), 13 [1095.8] (), 14 [1095.8] ()
                15 [1964.4] ()
System load averages (1min, 5min, 15min) : 2.8 %, 2.1 %, 1.9 %
Hyperthreading is enabled
Simulating `input.scs' on cadence at 6:47:47 PM, Thur Mar 12, 2026 (process id: 4708).
Current working directory: /home/fzapata/simulation/twork_1/netlist
Command line:
    /opt/cadence/SPECTRE241/tools.lnx86/bin/spectre -64 input.scs  \
        +escchars +log ../psf/spectre.out -format psfxl -raw ../psf  \
        +lqtimeout 900 -maxw 5 -maxn 5 -env ade  \
        +adespetkn= (long number here)  \
        -ahdllibdir  \
        /home/fzapata/simulation/tp_final/capacitances_calculation/maestro/results/maestro/Interactive.0/sharedData/CDS/ahdl/input.ahdlSimDB  \
        +logstatus
Simulation Id: ktuVgaS28d6R6sO3
Licensing Information:
[18:47:48.346113] Configured Lic search path (24.01-s002): 2100@localhost
Internal error found in spectre during license check-out.
    FATAL (SPECTRE-18): Segmentation fault. Encountered a critical error during simulation. Run `mmsimpack' (see mmsimpack -h for detailed usage information) to package the netlist and log files as a compressed tar file. Then, contact your Cadence representative or submit a service request via Cadence Online Support, including the tar file and any other information that could help identify the problem. Encountered a critical error during simulation. Run `mmsimpack' (see mmsimpack -h for detailed usage information) to package the netlist and log files as a compressed tar file. Then, contact your Cadence representative or submit a service request via Cadence Online Support, including the tar file and any other information that could help identify the problem.
****ASSERTION STACK****
        0x7ebf63c
        0xabaf5c
        0xabb512
        0x65450612990
        0x6544184e5af
        0x65441821ee5
        0x6544188f887
        0x65441896b8c
        0x6544189be8a
        0x6543c046836
        0x6543c02956c
        0x6543c01b360
        0x6543c01b7f7
        0x6543c016bdf
        0x6543c017023
        0x6543c0172d0
        0x90cb895
        0x90cbd19
        0x90846c7
        0x9084486
        0x9072fbf
        0x906b9e1
        0x906d613
        0x9068a49
        0x9068bab
        0x8bcab36
        0x8bbea3a
        0x8bbe24b
        0x8bbfd8a
        0x8bcb8aa
        0xba321c
        0xba67b4
****LIBRARIES****
        spectre/bin/64bit/spectre [0x400000]
        /usr/lib64/libpthread.so.0 [0x65450600000]
        /lib64/libc.so.6 [0x65441800000]
        /lib64/libudev.so.1 [0x6543c000000]
    Andrew Beckett 8 months ago
    Please try again using the latest SPECTRE24.1 or SPECTRE25.1 hotfix and if the crash still appears, you should contact customer support (use the case menu to submit a case after logging in) This will almost certainly need the netlist and for us to obtain the models used to ensure that we can reproduce the problem.
  • FZ20251125769
    FZ20251125769 8 months ago in reply to Andrew Beckett
    Hi Andrew! Thanks for the response.
    Where can I find the SPECTRE24.1/25.1 hotfix? (I'm new to the forum)
    Andrew Beckett 8 months ago in reply to FZ20251125769
    http://downloads.cadence.com
    This is where releases (including hot fixes) can be downloaded and installed. Whoever is responsible for your software installations should know how to do this, hopefully!
