  3. Gmindc different than the value set in the Options/anal...
  • Subscribers 136
  • Views 1524
Gmindc different than the value set in the Options/analog
JG20240913167
JG20240913167 7 months ago
Dear community,
When doing DC sweeps or stability analysis I have the issue that, the Gmindc used by the tool is 100 uS or even 1 mS. However, in the simulations options gmin and gmindc have been set to 1e-12.
Any idea what can I do to avoid the tool from using any other value than the specified?
I am using Cadence IC23.10.160, Spectre23.10.802.
The log looks like this
Global user options:
psfversion = 1.4.0
vabstol = 1e-06
iabstol = 1e-12
temp = -40
try_fast_op = no
gmin = 1e-12
gmin_check = all
gmindc = 1e-12
rforce = 1
maxnotes = 5
maxwarns = 5
digits = 5
cols = 80
dc_pivot_check = yes
pivrel = 0.001
sensfile = ../psf/sens.output
checklimitdest = sqldb
save = selected
currents = selected
reltol = 0.0001
tnom = 27
scalem = 1
scale = 1
Scoped user options:
Circuit inventory:
nodes 5481
bsim4 916
bsource_2ab5b1 258
bsource_09f256 2800
bsource_79a729 416
bsource_7533b7 426
bsource_bd39ed 1400
bsource_c39284 1613
bsource_rpldd_50k_noi_225128 60
bsource_rpposab_8ef6d6 48
capacitor 460
dac_8bit_ideal 1
diode 1933
iprobe 6
isource 1
resistor 1613
vccs 1
vdc8bit 1
vsource 15
Analysis and control statement inventory:
info 6
stb 1
Output statements:
.probe 0
.measure 0
save 0
Design checks inventory:
paramtest 1
assert 176
Notice from spectre during initial setup.
Protected devices exist and are not included in the circuit inventory.
365 warnings suppressed.
Time for parsing: CPU = 204.564 ms, elapsed = 510.794 ms.
Time accumulated: CPU = 718.18 ms, elapsed = 1.57563 s.
Peak resident memory used = 181 Mbytes.
Pre-Simulation Summary
Stability Analysis `stb': freq = (1 Hz -> 100 MHz)
Matrix is singular (detected at `I_DUT.I_MIRR_2_2.I_OPAs.D16.d0:int_c').
Warning from spectre during DC analysis, during STB analysis `stb'.
WARNING (SPECTRE-16085): Circuit has no unique solution.
A resistance of 10 kOhm (1/GminDC) was added across each nonlinear device.
Notice from spectre during DC analysis, during STB analysis `stb'.
GminDC = 100 uS is large enough to noticeably affect the DC solution.
    Andrew Beckett 7 months ago
    This is explained by Spectre can now adjust gmin value over a range automatically to resolve convergence issues . If you set gmindcmax you can limit the upper limit that gmindc will be adjust to in the case of "no unique solution".
    You can also just make the "Circuit has no unique solution" an error, following How to change spectre warning messages into error messages when Spectre determines that the circuit has no unique solution
  • JG20240913167
    JG20240913167 7 months ago in reply to Andrew Beckett
    Dear Andrew,
    Thanks a lot for your explanation and help. Unfortunately, the issue is still present. I set gmin=1e-14, gmindc=1e-14 and gmindcmax=1e-12.
    However, the simulator still uses Gmindc=100 uS. Any other idea?
    psfversion = 1.4.0
    vabstol = 1e-06
    iabstol = 1e-12
    temp = -40
    try_fast_op = no
    gmin = 1e-14
    gmin_check = all
    gmindc = 1e-14
    rforce = 1
    maxnotes = 5
    maxwarns = 5
    digits = 5
    cols = 80
    pivrel = 0.001
    gmindcmax = 1e-12
    save = selected
    currents = selected
    reltol = 0.0001
    tnom = 27
    scalem = 1
    scale = 1
    Circuit inventory:
    nodes 5481
    bsim4 916
    bsource_2ab5b1 258
    bsource_09f256 2800
    bsource_79a729 416
    bsource_7533b7 426
    bsource_bd39ed 1400
    bsource_c39284 1613
    capacitor 460
    dac_8bit_ideal 1
    diode 1933
    iprobe 6
    isource 1
    resistor 1613
    vccs 1
    vdc8bit 1
    vsource 15
    info 6
    stb 1
    Output statements:
    .probe 0
    .measure 0
    save 0
    paramtest 1
    assert 176
    Time for parsing: CPU = 205.993 ms, elapsed = 491.271 ms.
    Time accumulated: CPU = 709.027 ms, elapsed = 1.08937 s.
    Matrix is singular (detected at `I_DUT.I_MIRR_2_2.I_OPAs.D4.d0:int_c').
    Andrew Beckett 7 months ago in reply to JG20240913167
    First I would suggest checking with the latest SPECTRE25.1 ISR and if the issue persists, then please contact customer support (after logging in, use the case menu to submit a support case). We'll probably need your example netlist that shows the problem.
  • JG20240913167
    Understood. Thanks for your support
