  3. DC nested sweep of variables
  • Replies 16
  • Subscribers 136
  • Views 5826
Svilen64
Svilen64 7 months ago
My university uses a rather old Virtuoso version IC6.1.8-64b.83
I wanted to do a DC nested sweep of two variables but it failed. The simulation doesn't generate any errors, however it is just pending execution  until it eventually quits after 5 or so minutes. If I run a single sweep, there is no problem, everything is as expected. The cadence installation is local for each laptop in the computer lab. They just communicate with the server to get a license from what I know.
If I run the same nested sweep simulation on a much newer version at work, there is also no problem, everything is as expected.
Is there a known problem with nested sweeps in those older versions? Or could it be that particular university installation? Maybe someone has come across a similar issue. Just trying to figure out if I can somehow fix this.
Svilen
  • Svilen64
    Svilen64 6 months ago in reply to Svilen64
    also this
    $ ldd /home/student/cadence/installs/IC618/tools.lnx86/bin/cdsXvncd
        linux-vdso.so.1 =>  (0x00007ffefe1f6000)
        libnsl.so.1 => /lib64/libnsl.so.1 (0x00007f110be72000)
        libelf.so.1 => /lib64/libelf.so.1 (0x00007f110bc5a000)
        libstdc++.so.6 => /lib64/libstdc++.so.6 (0x00007f110b952000)
        libm.so.6 => /lib64/libm.so.6 (0x00007f110b650000)
        libgcc_s.so.1 => /lib64/libgcc_s.so.1 (0x00007f110b43a000)
        libc.so.6 => /lib64/libc.so.6 (0x00007f110b06c000)
        libz.so.1 => /lib64/libz.so.1 (0x00007f110ae56000)
        /lib64/ld-linux-x86-64.so.2 (0x00007f110c08c000)
    Andrew Beckett 6 months ago in reply to Svilen64
    Ah, sorry, my mistake. cdsXvncd is a 64-bit executable that then invokes cdsXvnc (a 32-bit executable). My guess is that this can't be launched for that reason. Can you check:
  • Svilen64
    Svilen64 6 months ago in reply to Andrew Beckett
    I will have to check that on Friday. That's when I will go back there for the class.
  • Svilen64
    I ran ldd /home/student/cadence/installs/IC618/tools.lnx86/bin/cdsXvnc
    The message I got is "the executable file is not dynamically linked"
    Also, the file is statically compiled.
    Svilen
    Svilen,
    That's very odd. What does "file /home/student/cadence/installs/IC618/tools.lnx86/bin/cdsXvnc" output. For me:
    UNIX> file /cds/lnx86/static/IC618_cd/tools.lnx86/bin/cdsXvnc
    /cds/lnx86/static/IC618_cd/tools.lnx86/bin/cdsXvnc: ELF 32-bit LSB executable, Intel 80386, version 1 (SYSV), dynamically linked (uses shared libs), for GNU/Linux 2.2.5, not stripped
    I can't work out how yours shows that it's not dynamically linked.
    For me, ldd shows:
    UNIX> ldd /cds/lnx86/static/IC618_cd/tools.lnx86/bin/cdsXvnc
    linux-gate.so.1 => (0x555c9000)
    libdl.so.2 => /usr/lib/libdl.so.2 (0x555cb000)
    libstdc++.so.5 => /usr/lib/libstdc++.so.5 (0x555d0000)
    libm.so.6 => /usr/lib/libm.so.6 (0x55689000)
    libgcc_s.so.1 => /usr/lib/libgcc_s.so.1 (0x556cb000)
    libc.so.6 => /usr/lib/libc.so.6 (0x556e7000)
    /lib/ld-linux.so.2 (0x555a5000)
    Checking these shared libraries they come from these RPMs (note, I was checking on an RHEL7.9 machine, so versions may vary) - these are all the 32-bit RPMs:
    • glibc-2.17-317.el7.i686
    • compat-libstdc++-33-3.2.3-72.el7.i686
    • libgcc-4.8.5-44.el7.i686
    Are those installed? Do the shared libraries mentioned above in /usr/lib exist on your machine?
    To be honest, it would be far more efficient to move to using a more recent version (even the latest IC6.1.8 hotfix) rather than an (almost) 8 year old installation.
  • Svilen64
    Thanks Andrew,
    I will relay your reply to the sys admin.
