  3. DC nested sweep of variables
  • Replies 16
  • Subscribers 136
  • Views 5825
Svilen64
Svilen64 7 months ago
My university uses a rather old Virtuoso version IC6.1.8-64b.83
I wanted to do a DC nested sweep of two variables but it failed. The simulation doesn't generate any errors, however it is just pending execution  until it eventually quits after 5 or so minutes. If I run a single sweep, there is no problem, everything is as expected. The cadence installation is local for each laptop in the computer lab. They just communicate with the server to get a license from what I know.
If I run the same nested sweep simulation on a much newer version at work, there is also no problem, everything is as expected.
Is there a known problem with nested sweeps in those older versions? Or could it be that particular university installation? Maybe someone has come across a similar issue. Just trying to figure out if I can somehow fix this.
Svilen
    Andrew Beckett 7 months ago
    Svilen,
    It's probably an installation issue (there's no generic issue with the older version). Can you run "virtuoso -nograph" with the older version?
  • Svilen64
    Svilen64 7 months ago in reply to Andrew Beckett
    Thanks for replying. It looks that installation is buggy. Anything that requires a sweep doesn't work. I tried running Monte-Carlo and and it behaved the same - pending indefinitely until it eventually quits.
    I ran virtuoso -nograph and nothing really happened. The machine was just trying stuff and here is the result. What do I make of it?
    *WARNING* Unable to open -nograph X Window Display "laptop2:80"
    *WARNING* (using "exec /home/student/cadence/installs/IC618/tools.lnx86/dfII/../bin/cdsVncserver :80 -co /usr/share/X11/rgb&").
    *WARNING* cdsXvnc output may be found in file $HOME/.vnc-cds/laptop2:80.log
    Trying another display...
    Svilen
    Andrew Beckett 7 months ago in reply to Svilen64
    When you simulate more than one point, then it will run various things in the background using a "virtuoso -nograph" (certainly in the older version you're using). Using virtuoso -nograph starts (at least it did in that version) a VNC session to consume all the graphical output.
    What does it says in the cdsXvnc log files mentioned in the above messages? (i.e. $HOME/.vnc-cds/laptop2:80.log).
  • Svilen64
    I will have to check the cdsXvnc when I go back to the university lab. Will keep you posted.
  • Svilen64
    Svilen64 6 months ago in reply to Svilen64
    I checked the cdsXvnc log file. It only has one line in it but it spells problem
    /home/student/cadence/installs/IC618/tools.lnx86/bin/cdsXvncd: execv returned -1, errno = 2
    What does it mean?
    Svilen
    Andrew Beckett 6 months ago in reply to Svilen64
    This almost certainly means you're running on an OS without the necessary 32-bit libraries installed. cdsXvncd is a 32-bit executable, and won't run if those libraries are not installed (the errno=2 means "No such file or directory" but is not very explicit as to what the problem is).
    Try running:
    and seeing what happens. Then try:
    ldd /home/student/cadence/installs/IC618/tools.lnx86/bin/cdsXvncd
    to see what it reports about shared libraries.
    What OS are you using? What does:
    cat /etc/os-release
    show?
  • Svilen64
    Svilen64 6 months ago in reply to Andrew Beckett
    The University is using Centos 7 on those computers in the lab.
    Thanks. Can you answer the other questions? I need that information too.
  • Svilen64
    Yes, I will answer when I go to the lab and try those things. I am not there now.
  • Svilen64
    Here is what I got after running the things you requested:
    $ /home/student/cadence/installs/IC618/tools.lnx86/bin/cdsXvncd
    Svilen
