  3. Liberate : error about "tcl command set" in lvf charact...
  • Subscribers 136
  • Views 718
Liberate : error about "tcl command set" in lvf characterization
WZ202603266450
WZ202603266450 7 months ago
Hi, all:
    Recently I try to use liberate to characterize LVF for some stdcells in unified flow, but when I use “packet_mode cell" it will generate error:
  "Error - Tcl command set ::grid_bundle_dir exited with an error can't read "::grid_bundle_dir" : no such variable" when it start characterization bundle.
  I try to set that variable in char.tcl or use local host rather than distribution system, which can not fix that error. Therefore, I wanna ask some help for fixing this error.
  Liberate version: liberate/21.8.0
  packet command:
set packet_clients 100
set threads 2
set rsh_cmd "bsub -q ${bqueue} -R ‘span\[hosts=1\]’-n ${threads} -o %B/log -e %B/log"
set_var heartbeat_timeout 1200
set_var packet_clients ${packet clients}
set_var packet_client_log_timeout [expr { 1 * 3600 }]
set_var packet_client_timeout [expr { 3 * 3600 }]
set_var packet_client_timeout action "error"
set_var packet_client_resubmit count 5
set_var packet_log_filename "log
set_var packet_rsh_mode lsf
set_var bolt_optimize_client_submission 1
set_var packet_arc_job manager traditional
set_rsh_cmd $rsh_cmd $cells
set_var packet_mode "cell"
  • Guangjun Cao
    Guangjun Cao 7 months ago +1
    Hi, Is there a particular reason that you want to use packet_mode=cell? It is an option that was developed for older Liberate when the packet flow was first developed. arc mode is more efficient. MPVT…
  • Guangjun Cao
    Is there a particular reason that you want to use packet_mode=cell? It is an option that was developed for older Liberate when the packet flow was first developed. arc mode is more efficient. MPVT flow would support arc mode only.
    If you insist on using cell mode, please file a case and let a local AE to file a CCR on this issue.
    guangjun
