  3. How to Disable Auto-Execution of Animate Preview on Schematic...
  • Subscribers 136
  • Views 1582
How to Disable Auto-Execution of Animate Preview on Schematic Open to Fix Large Design Lag
Hopken
Hopken 7 months ago
Hi everyone,
I'm encountering an issue where Animate Preview automatically runs immediately every time I open a schematic in Virtuoso. This causes severe lag and slow loading when working with large, complex circuits, as the preview process consumes significant system resources during schematic launch.
I want to completely disable the automatic execution of Animate Preview on schematic open, and only trigger it manually when needed. Could anyone share:
  1. The environment variables, SKILL variables, or configuration settings that control this auto-run behavior
  2. How to permanently disable the auto-preview feature
  3. Any workarounds to prevent Animate from running automatically at schematic load
Thanks  for your help!
  • Andrew Grantham
    Andrew Grantham 7 months ago
    Animate as default automatically runs on schematics which have less that 100 instances.  This can be changed using the env var :
    PULSIC_ANIMATE_AUTOMATIC_RUN_MAX_INSTANCE_COUNT
    If you set this to 0, then Animate will only run when you press the play button on the Animate Assistant.
    Best Regards,
  • Hopken
    Hopken 6 months ago in reply to Andrew Grantham
    Thank you so much for your prompt and clear reply! The issue has been perfectly resolved with the environment variable you provided. I really appreciate your expert guidance and support!
    Best regards,
    JH202604155337
