  3. Update NLPlabel with Skill
  • Subscribers 136
  • Views 1255
DH202603191437
DH202603191437 7 months ago
Hi all,
I have an issue with updating NLPlabel on given pcell from pdk. Symbol of the pcell has [@info] label, type NLPLabel. Default value for the pcell is [@libName]:[@cellName]:[@instanceName]. When I place it into schematic, it is working well and "info" label is in schematic shown like this: realLibrary:realCellName:I1. The problem is, that I would like to change it with Skill script. When I try to change it by car(selectedSet())~>info = "[@cellName][@instanceName]", it is renamed to text  "[@cellName][@instanceName]", but in schematic I see exact plain text instead of realCellName:I1 (@cellName and @instanceName are shown as text, not executed or updated to real names of instance and cell). This happens, when I try to update it directly after placing pcell to schematic. When I place pcell to schematic, change "info" label manually and then update it using skill script, it is working as expected - @instanceName and @cellName are shwon as real values.
Is there an function, how to force labels to update values? Or other way, how to udpate "info" label with executed @values.
Thank you very much
Denis
    Andrew Beckett 7 months ago
    Denis,
    Rather than setting the value of the property using inst~>info="..." you should use dbReplaceProp with something like:
    dbReplaceProp(car(selectedSet()) "info" "NLPExpr" "[@cellName]:[@instanceName]")
    By setting it directly, you're converting into a string property (it infers the property type from the type of the value). I assume the default info is an NLPExpr.
  • DH202603191437
    DH202603191437 6 months ago in reply to Andrew Beckett
    it is working well, thank you very much.
    Denis
