  3. Combining multiple calculator outputs into a vector/bus...
  • Subscribers 136
  • Views 990
Combining multiple calculator outputs into a vector/bus in Virtuoso Assembler
baltaci
baltaci 6 months ago
I’m using the Virtuoso Assembler Calculator (IC23.1-64b.43) to define multiple output expressions (e.g., dout_0, dout_1, …, dout_63). These are all analog waveforms created via expressions.
All of these waveforms share the same time axis (same independent variable / time sweep), i.e., they are aligned sample-by-sample in time.
What I would like is to combine these individual calculator outputs into a single vector/bus-like waveform, similar to how one can access a bus using:
VT("/bus<63:0>")
So essentially:
dout_0, dout_1, ..., dout_63  →  dout_bus[63:0]
What I tried:
  • Using vector(...) in the Calculator → did not work
  • Using SKILL function awvCreateBus → works only for digital waveforms
Questions:
  1. Is there a way in the Calculator or Assembler to group multiple analog waveforms (with the same time axis) into a single vector/bus?
  2. Is there any supported function (Calculator or SKILL) for analog waveform grouping?
  3. If not, what is the recommended workflow for handling large numbers of related outputs?
Thanks!
Can
  • JankoK
    JankoK 6 months ago
    Hi Can,
    Good question that sounds very familiar... I think I was trying to do the same, but can't find anything in my notes.
    I guess you could use this SKILL function from Andrew Beckett  if you want to stay "analog":
    How to create a group of signals in the calculator?
    Or, if it is ok for you to go digital, you can try this one:
    SKILL procedure to create a digital bus from a list of analog signals
    BR
    /Janko
