  3. How to use getData() without hardcoded results path, for...
  • Subscribers 136
  • Views 1339
How to use getData() without hardcoded results path, for a DC sweep?
dontpanic
dontpanic 6 months ago
Hi! I am unable to get getData() to work without hardcoding the results path for sweeps.
For example if I define the following 3 outputs in a simple DC sweep (variable PATH_TO_DEVICE is a string equal to "DUT.MN"):
output1 getData("DUT.MN:gm" ?result "dc")
output2 getData(strcat(VAR("PATH_TO_DEVICE") ":gm") ?result "dc")
output3 getData(strcat(VAR("PATH_TO_DEVICE") ":gm") ?result "dcOpInfo")
then output1 and output3 evaluate / plot  properly, while output2 produces the error attached below.
The error seems to be that VAR("PATH_TO_DEVICE") returns a srrWave object instead of a string for the DC sweep results (the same expression works fine for the dcOpInfo results in output3!)
How can I workaround this problem? Thanks in advance for any help!
Jorge.
*Error* ("strcat" 0 t nil ("*Error* strcat: argument #1 should be either a string or a symbol (type template = \"S\")" srrWave:0x7094c0b0))
ERROR (ADE-1057): Could not evaluate expression
        Expression:'getData(strcat(VAR("PATH_TO_DEVICE") ":gm") ?result "dc")'
     because of the following error(s)
     Ensure that the definition of the expression is correct.
    Andrew Beckett 6 months ago in reply to dontpanic +1
    Because the variable could (potentially) have different value per sweep point, it becomes a waveform (or family of waveforms, depending on on the depth of sweeps). For output3 this works because the…
  • dontpanic
    * I meant, "without hardcoding the SIGNAL path" (the results path is not the issue here)
    For output3 this works because the result for each simulation point will be a scalar value. Because of that, it's computed after each individual simulation and at that point the VAR() will be a string and so the expression works OK. For output2 the result at each simulation point is computed (it's OK, because the VAR is a string) and is determined to be a waveform (because it's from the dc sweep itself). Because it's a waveform, nothing is stored and you just get a waveform icon showing. When you try to plot the waveform at the end, it will then access the entire data set and at this point VAR() is returning a waveform - hence the problem.
    The solution is to use the leafMap function around your expression. This magically handles the fact that part of the expression is a waveform/ family:
    leafMap(getData(strcat(VAR("PATH_TO_DEVICE") ":gm") ?result "dc"))
