  3. spectre nodes info: pin names different than what is in...
  • Subscribers 136
  • Views 1887
spectre nodes info: pin names different than what is in schematic or input.scs
marcelpreda
marcelpreda 6 months ago
Hi *,
I'm trying to get the instances connectivity through hierarchy, the mapping hier.inst_name:pin to hier.net_name
I'm using the spectre  "info what=nodes"
It works, but I have two problems with some device models (the real model names were hidden, so I've use "abc", "xyz", ...)
#1 issue - for some devices instead of pin names in nodes.info, I get the the pin numbers.
It seems to happen for all capacitor and resistor types.
capacitor: C0 of zzz
1 : net392
2 : 0
Instead of "1", "2" preferable to have "p", "n".
#2 - Some devices are netlisted in input scs as caps C2 (net1 0 v_pwell) xyz value=11f wlratio=1 but on the nodes.info file I get a different type and a numbers of pins.
bsim4: C2 of abc
d : 0
g : net1
s : 0
b : 0
I had a look in the model files and the reason is that xyz 3 pins capacitor model is derived from a MOS card model (bsim4), like below (xyz - xyz_p - abc card model) :
xyz (p n b) xyz_p ...
ends xyz
xyz_p (n p n n) abc ...
ends xyz_p
abc (d g s b) abc_modelcard l=l w=w ad=ad as=as pd=pd ps=ps nrd=nrd nrs=nrs trise=trise
ends abc
model abc_modelcard bsim4 ....
Is there any option to get the pin names as they are in the .scs ?
  • for caps/res to get (p n)
  • for the other to get the pins from "top" model , e.g "(p n b) of xyz" insetad of "(d g s b) of abc"
Preferable some other spectre param/option , and then to parse 1-2 files, if there is a need to parse multiple files/db I'm OK with that too.
I have no control on models definition.
Thank you,
Marcel
Sorry for bad formatting, but when try to use "code" tags, the post was not submitted .
  • marcelpreda
    Added the specre options
    saveOptions options save=all currents=all subcktprobelvl=3simulatorOptions options psfversion="1.4.0" reltol=1e-2 vabstol=1e-4 \
    iabstol=1e-10 temp=27 tnom=27 scalem=1.0 scale=1.0 gmin=1e-12 rforce=1 \
    note=yes maxnotes=5 warn=yes maxwarns=5 digits=5 cols=80 pivrel=1e-3 \
    sensfile="../psf/sens.output" checklimitdest=file \
    inlinesubcktcurrent=subckt useterms=name
    tran tran stop=100n write="spectre.ic" writefinal="spectre.fc" \
    method=euler annotate=status maxiters=20
    asserts info what=assert where=rawfile
    nodes_2 info what=nodes where=file
    terminals info what=terminals where=file
    Maybe I've miss some useful option.
    Thank you,
    Marcel
    Andrew Beckett 6 months ago in reply to marcelpreda
    Hi Marcel,
    I've checked, and I don't think there's any way to dump the nodes for subckt instances; it only outputs the leaf device information.
  • marcelpreda
    marcelpreda 6 months ago in reply to Andrew Beckett
    Thanks a lot.
    Best Regards,
    Marcel
