  3. Density command query related to Pegasus.
  • Subscribers 136
  • Views 444
SB202511198144
SB202511198144 5 months ago
density Metal15 -lt 0.6 -inside_of layer metalx -by_polygon -rdb "out.density.rdb"
In Pegasus DRC rule writing, I am using above command. where I am try to check the density of the Metal15 under metalx and highlighting the metalx if the density is less than 60% . during this execution to calculate the density the command is taking the area of the bbox  that is enclosing the circle, this behavior is leading to false flags hence to consider the area of circular shape metalx instead of bbox of that circle, what changes should i need to do in the above specified command.
