  3. Memory usage during simulation
  • Views 1233
dogman4
dogman4 5 months ago
Hi friends
  I simulate the circuit with assembler in presim; the circuit is rather complex and is a boost circuit. I only selected to save around 1000 waveforms in total. The simulation runs with tran:conservative, and the high performance settings are :APS ; Error Preset: Moderate;   Use ++aps selected;    #threads:24(Sorry, an error occurred when I tried to upload the picture.)
Here is my issue: during simulation, I set three voltage states via global Variables within the same assembler and run three simulations simultaneously. The three simulations differ only in voltage settings. Everything works normally at the start of the simulation, and the VIRT and RES usage checked via the TOP command in the terminal are within normal ranges. However, as simulation time elapses — for instance, after four days of continuous simulation this time — the memory usage diverges drastically: 1st simulation: VIRT: 97.6g, RES: 97g. 2nd simulation: VIRT: 63.1g, RES: 62g. 3rd simulation: VIRT: 7000m, RES: 8.1g Moreover, VIRT and RES keep rising steadily as the simulation runs longer.
What configuration adjustments can I make to keep VIRT and RES within a normal range of several gigabytes?
very thanks in andvance
My virtuoso version: "@(#)$CDS: virtuoso version 6.1.8-64b 09/03/2024 19:11 (sjfhw316) $"
My spectre version: Version19.1.0.063 64bit--10 Aug 2019
  • dogman4
    title should be:  High memory usage during simulation
    Andrew Beckett 5 months ago in reply to dogman4
    You didn't say which process was consuming a lot of memory. I assume it's not Spectre itself (I can't see why the memory consumption would increase in a transient sim over time) - is this the virtuoso used for the ICRP?
    Not really enough info to go on. Using LSCS would likely help there rather than ICRP, but even then I'm guessing.
    Contacting customer support would be the best option here.
  • dogman4
    dogman4 5 months ago in reply to Andrew Beckett
    oh,Andrew.
    it is spectre consuming a lot of memory.and I use lscs
  • dogman4
    dogman4 5 months ago in reply to dogman4
    3 spectre.1st spetre: VIRT: 97.6g. RES: 97g. 2nd:VIRT: 63.1g, RES: 62g. 3rd: VIRT: 7000m, RES: 8.1g
    The first thing I would suggest is use a version Spectre that is newer than 7 years old, and try with Spectre X. If that doesn't resolve it, you will need to contact customer support as I mentioned earlier.
    There isn't enough information here to be able to pinpoint anything...
