  3. Parameterization of Hidden Parameters
  • Subscribers 136
  • Views 767
JT202409108313
JT202409108313 5 months ago
Is there a way to add to Assembler's parameter list those device parameters that may be hidden (AKA Display Condition is not blank/t)?
Constraint is that the Display Condition cannot be edited but the condition can be triggered once the device is used in a circuit.
I can trigger it to show, add it to parameter list, then trigger it to hide again and I think that would pose no problem when I sweep it. However, that would be much of a hassle if I will do it for all instances of the device on different subblocks. Is there a way to make it faster?
    Andrew Beckett 5 months ago
    There has been a recent change in IC25.1 ISR4 to allow this, but it's currently behind a private environment variable. I have asked the team why this has been done this way. The relevant change request (CCR) is #3241861 - please contact customer support to indicate that you need this.
