  3. python version of cds_srr
  • Subscribers 136
  • Views 766
AC202503109020
AC202503109020 5 months ago
I like to use the cds_srr tool from matlab to process psf data from our simulations.
Matlab requires an expensive license however and it is quite difficult to build easy-to-use command line tools for my users with it.
Is there a python equivalent tool which does similar things?
    Andrew Beckett 5 months ago
    There is something called CDSPYTHONSRR which was introduced in IC23.1 ISR12 (it was available as a standalone kit on request before that) which allows you to read simulation results directly into Python. This doesn't cover everything that you can do with the ADE MATLAB interface (it's closer to the standalone Spectre toolbox for MATLAB), and there's no integration into ADE (so you can't have python expressions in the output). There's an enhancement CCR for that - 2052789 - with a few duplicates. If this is what you want, you should contact customer support (submit a case after logging in) and request a duplicate is filed on your behalf.
