  3. In Cadence Maestro, I want to create a calculator funct...
  • Views 933
In Cadence Maestro, I want to create a calculator function
Mooh
Mooh 4 months ago
In Cadence Maestro, I want to create a calculator function. I want the function to plot a vcsv file; it takes the path of the file and plots it as simply as that
    Andrew Beckett 4 months ago
    Given that VCSV files can contain more than one signal, you might need more than that (e.g. which column number you want for X and Y). The good news is that there's an existing calculator function that does this - you don't need to create a new one:
    getAsciiWave("jitter.vcsv" 1 2 ?xskip 0 ?yskip 0 ?formatFloat nil ?xName "time" ?xUnits "s" ?yName "V" ?yUnits "V" )
    It already ignores the comment columns at the top.
  • Mooh
    Mooh 4 months ago in reply to Andrew Beckett
    That worked perfectly, thank you so much! One more question: do we have a similar function for S-parameters? Ideally, it would take the S-parameter file path and information, then plot S11 or S21 as an example otherwise I need to run a sp simulation with nport cell .
    Andrew Beckett 4 months ago in reply to Mooh
    getData("s1,1" ?result "nrc_pkg_24port" ?resultsDir "/path/to/nrc_pkg_24port.s24p")
    The ?result would be the prefix for the file name, and the first argument is of the form "sN,M".
  • Mooh
    Thank you so much
