  3. How to use 500 bit conversion analog to digital express...
  • Subscribers 136
  • Views 1445
How to use 500 bit conversion analog to digital expression
RM202605273230
RM202605273230 4 months ago
Hello
I am trying to convert 500 bits from analog.to digital and use in expression in Adexl.bit its taking upto 149 only how to use 500 directly could you please let me know Thank you
    Andrew Beckett 4 months ago
    This question makes no sense. Please explain more clearly what you are trying to do and what you have tried so far.
  • RM202605273230
    RM202605273230 4 months ago in reply to Andrew Beckett
    "I have 500 output signals because I instantiated the same cell 500 times, resulting in 500 individual outputs. I want to convert these 500 signals into one analog-to-digital expression. In ADE XL, I selected the analog-to-digital conversion options and set the value range. However, even when I tried manually entering all 500 bits, ADE XL automatically limited the expression to only 149 bits. So, even in the worst case, it still truncates the output. How can I configure ADE XL so that all 500 signals appear in a single expression? I need all bits included in the output format after the setup, rather than being truncated to just 149."
    Andrew Beckett 4 months ago in reply to RM202605273230
    Where are you selecting "the analog-to-digital conversion options and set the value range"? Are you actually using ADE XL (which is an end-of-life product) or ADE Explorer/Assembler?
    Which IC sub-version are you using?
    Where did you "manually enter" all these bits?
    I'm trying to work out exactly what you did, as it's (still) not clear.
  • RM202605273230
    To clarify the steps and the environment I am using, here are the details of my setup:
    1. Tool and Environment Tool: I am indeed using Virtuoso Analog Design Environment XL. IC Sub-version: I am running IC6.1.8-64b.
    2. Selecting "Analog-to-Digital" and Setting the Range in the Virtuoso Visualization & Analysis XL waveform viewer. From the top menu, I navigate to Measurements -> Analog To Digital. This opens the Analog to Digital dialog box, where I select the signal VT("/OUT<499:0>") and attempt to configure the threshold and logic center values.
    3. Manually Entering the Bits / Expression Limitation I am entering the expression directly into the Outputs Setup tab of the main ADE XL window. Under the Details column for the expr type, I am using the awvCreateBus function combined with awvAnalog2Digital to stitch the bits into a single bitstring bus: value(awvCreateBus("OUT_BITSTRING" list(awvAnalog2Digital(VT("/OUT<31>")... When I manually expand this list to include all bits for the larger bus (up to 500 bits), the ADE XL expression field automatically truncates the string, cutting it off after it reaches roughly 149 bits. Even with the proper conversion process selecting "Analog-to-Digital" and setting the range in that dialog, it still reduces to 149 bits.
    Please let me know if there is a more efficient function or a preferred method to handle large bit-width bus conversions in this version without hitting expression character limits.
    sorry for the early message confusion
    Interactively (at least using the latest IC25.1 version; I didn't go back and check your old version) it works interactively in ViVA creating the bus. However, the problem with generating an output expression in ADE for this is that the expression gets very long and unwieldy.
    I suggest trying to use a combination of the SKILL code in this post: abDumpWaveformsToVCSV.il (this should be loaded from your .cdsinit), and also abA2Bus.il from here
    In the ViVA calculator, in the function panel, use the "fx" button to navigate to the abA2DBus.il code and then you'll be able to use it from the calculator. Using an expression such as this should then work:
    abA2DBus(VT("/op<499:0>")  "center" ?vCenter 0.9
  • RM202605273230
    Thank you for the information
