  3. ADE Explorer: How to pass a design variable to a parameter...
  • Subscribers 136
  • Views 760
ADE Explorer: How to pass a design variable to a parameter array and another design variable as a string parameter to an instance - Spectre vs. AMS
Volker T
Volker T 4 months ago
I am referring to the following two blog posts, both dealing with ADE Explorer and/or Spectre, as an introduction to a similar problem I have with ADE Explorer and AMS.
ADE Explorer and Spectre
1. How to Pass a String Design Parameter to a Cell
2. Defining Verilog-A vector in the maestro view
The first deals with the issue that when we have a parameterizable cell, like e.g. an instance "myInstance" of a cell using a Verilog-A view, that has a string parameter, e.g. "fname" that we want to specify by design variable, the Spectre netlist does not contain the value of the design variable, but its name only.
Example:
At the beginning of the Spectre netlist, we see the parameters passed to Spectre, e.g.
parameters temperature=27 vdd50=5 fname="/tmp/mylogfile.log" \
debuglevel=1 tperiod=50n trise=100p tsdelay=10n
But later in the netlist, when we look at the instance "myInstance" that receives some of these parameters, one of which is the "fname" string parameter, we only see
myInstance trise=trise tfall=trise tdelay=0 \
        tsdelay=tsdelay tperiod=tperiod vdd=vdd50 logfile="fname"
So, instead of our string defined by design variable value, we only see the design variable name as a string passed to the instance's string parameter "logfile",
The solution shown by Andrew Beckett suggests to use SKILL functions to remove the respective string parameter while leaving the other string parameters in place:
almGetStringParameterList("mylib" "mycell" ?view "veriloga")
=> (fname someOtherParam somethingElse)
almSetStringParameterList("mylib" "mycell" '(someOtherParam somethingElse) ?view "veriloga")
=> (someOtherParam somethingElse)
The former function identifies all string parameters used by the respective view of a cell of a library (fname, someOtherParam and somethingElse in the example shown) and then the latter function can be used to set the same list minus the string parameter we would like to pass by design variable (e.g. fname) as the new string parameter list. That way, our Spectre netlist gets the value of the string parameter, and not only its name.
Now the beginning of the Spectre netlist still looks like this:
But later in the netlist, when we look at the instance "myInstance" that receives some of these parameters, one of which is the "fname" string parameter, we now see
        tsdelay=tsdelay tperiod=tperiod vdd=vdd50 logfile=fname
So, instead of "fname" (in quotes, hence being a string), we only see fname without quotes, hence referencing the respective Spectre parameter.
Problem solved, instance parameter "logfile" is now fed by Spectre parameter "fname" containing string value "/tmp/mylogfile.log" of design variable "fname"..
The second post deals with parameter arrays. Again, let's assume we use an instance of a cell using a Verilog-A view, that has a parameter array, like
parameter integer pattern[2:0] = {1, 2, 3};
and we would like to use a design variable "myPattern" for the definition of the pattern, in ADE, then we cannot just enter [4 5 6] for that design variable value to define a new pattern, as ADE interprets that as a literal or SKILL code.
Andrew Beckett shows the solution for this in the referenced post #2, namely to use strcat("[4 5 6]") as design variable value instead. This gives valid SKILL code for ADE, translates into string "[4 5 6]", which translates into Spectre parameter [4 5 6].
Example:
At the beginning of the Spectre netlist, the parameter list now is
parameters myPattern=[4 5 6] vdd50=5 fname="/tmp/mylogfile.log" \
Later, when the respective instance occurs in the netlist, we see something like
myInstance trise=trise tfall=trise tdelay=0 pattern=myPattern\
So, similar to the string parameter described before, the instance parameter now gets assigned the correct Spectre parameter.
So far, so good, problems solved for ADE Explorer and Spectre.
Now let's use the same test bench, using the same cells and design parameters, but AMS as a simulator. As far as I know, AMS uses a different netlister (UNL?), and that apparently behaves differently.
The instance now gets its parameters assigned like this
myInstance #(.trise(cds_globals.trise), .pattern("myPattern") .tperiod(cds_globals.tperiod), .tsdelay(cds_globals.tsdelay), .vdd(cds_globals.vdd50), .tdelay(0), .tfall(cds_globals.trise), .logfile("fname"), .debuglevel(cds_globals.debuglevel)) I1 (.nrst( nreset ), .mclk( mclk ), ... );
There is no "pre-translation" of design variables into AMS parameters to be found as a list (but apparently there exists one, named "cds_globals", as one can see for the other parameters). But both the string parameter and the array parameter do not show up in cds_globals but are used directly as a string containing the design variable name instead of its value.
So the question is, is there any trick similar to the two shown for Spectre that we can create a netlist using design variable values instead of design variable names?
