  3. Import def file , get wrong coordinate , it has 0.0005 offset...
  • Subscribers 136
  • Views 413
Import def file , get wrong coordinate , it has 0.0005 offset (0.1645 to 0.165)
Charley Chen
Charley Chen 4 months ago
Hi All,
I have a layout , draw a shape at 0.1645:35.056  ... , generate def as below , but when  GUI -> Import - DEF In to verify ,
It get wrong coordinate , it has 0.0005 offset (0.1645 to 0.165) , but shape width is the same.
How to fix this problem?
DEF file partial net as below:
VERSION 5.8 ;
UNITS DISTANCE MICRONS 1000 ;
PIND 10 ;
- VV + NET VV
+ DIRECTION INPUT
+ USE SIGNAL
+ PORT
+ LAYER ME1 ( 0.0000 0.0000) (76.0000 152.0000)
+ PLACED (164.5000 34904.000 ) N ;
Charley
  • Charley Chen
    Hi All ,
    It needs to adjust UNITS DISTANCE MICRONS 2000 can fix the problem.
    Charley
