  3. Why in 2026 still unable to rotate text labels by 45 degrees...
  • Subscribers 136
  • Views 411
Why in 2026 still unable to rotate text labels by 45 degrees in symbol view?
SH20260513571
SH20260513571 2 months ago
Using latest and greatest Virtuoso Advance Node, I want to rotate some text labels by 45 degrees in a symbol view. Either by the GUI, or, if not possible (and prefered) using the SKILL backdoor. Reason being: to make the symbol be actual useful, i add diagrams to it, and for the pump-pad + IO cell I want to add text labels to the bump map, but the labels are overlapping. If I had the chance to rotate the labels, they wouldn't overlap anymore.
I'm asking for 45 degrees, but any multiple of 15 degrees would be even better, or multiples of 1 degree, if I may be greedy.
Why isn't something simple like this not possible in Virtuoso in 2026? Or if it is: why can't I find it?
With kind regards,
Sjoerd Herder
    Andrew Beckett 2 months ago
    Hi Sjoerd,
    This is set by the available orientations in the underlying OpenAccess database (from Si2). That only supports the 8 90-degree orientations.
