  3. How to save PEX post-sim waveforms the same way as pre-sim...
  • Views 617
How to save PEX post-sim waveforms the same way as pre-sim?
dogman4
dogman4 1 month ago
Hi friends
    I extracted the PEX parasitic netlist using Calibre v2016.2_39.26 and then performed post-simulation analysis in Assembler.
Before running the pre-simulation, I add the signals I want to monitor to the "Outputs Setup" and set "Save options" to the selected mode. After the simulation is complete, I can directly plot the waveforms within Assembler.
Now, I want to adapt this workflow for post-simulation: adding the target waveforms to the "Outputs Setup" and then select selected for "Save options".
    Does anyone have advice on how to do this?
My virtuoso version: "@(#)$CDS: virtuoso version 6.1.8-64b 09/03/2024 19:11 (sjfhw316) $"
My spectre version: Version19.1.0.063 64bit--10 Aug 2019
页面翻译
  • dogman4
    dogman4 1 month ago
    by the way, my pex is spectre format
  • dogman4
    dogman4 1 month ago
     Furthermore
    Currently, for post‑layout simulation, I first use Save All, then select the desired nets and send them to Outputs Setup for plotting. However, Save All generates excessive data, so I need to switch to the  selected  mode for subsequent runs. When using  selected  mode, the saved signals cannot be plotted after post‑simulation.
    Therefore, it would be acceptable if I could place the post‑simulation net names into Outputs Setup, set Save to  selected , and directly plot the waveforms after running post‑layout simulation.
    Andrew Beckett 1 month ago in reply to dogman4
    The best solution would be to move to IC25.1 and then you can use IDSPF views (if using Quantus), or if you're using parasitic extraction from Calibre, you can then use the DSPF2ADE flow. This then would allow the output names to remain as the schematic names and it can automatically map them.
    This is covered in this Rapid Adoption Kit: DSPF2ADE flow (IC25.1)
