  3. Can clip() support multiple time windows?
  • Subscribers 136
  • Views 356
Johanny Saenz
Johanny Saenz 1 month ago
Hi all.
I want to calculate a waveform metric while excluding specific time intervals containing switching glitches.
The glitches occur when a control signal changes state, so I can identify the relevant time points using cross(). For a single interval, I can use something like:
clip(waveform t_start t_stop)
However, I would like to evaluate the waveform over multiple non-contiguous time windows, effectively excluding the intervals around each detected transition.
Does the Cadence Calculator clip() function support multiple time ranges, possibly using the output of cross()? If not, what is the recommended Calculator/SKILL approach to calculate, for example, ymin() while ignoring these glitch intervals?
Thanks in advance
    Andrew Beckett 1 month ago
    Nothing built-in as far as I know. There is my article 20374821 which provides a function abFilterByValue - this allows you to filter out any values outside a given range. It also provides a way to filter out based on X ranges too - but it only supports a single X range at the moment (and anything in that range is omitted; you might want the opposite) - it might be a good starting point for what you want though.
