  3. Netlist error
  • Subscribers 137
  • Views 243
Netlist error
DA202602028132
DA202602028132 1 month ago
Hello
I am currently running a test containing emx extraction (s param file)
How have I assembled the test ?
to do so, I have created schematic and schematic_emx cellviews
schematic_emx just has instance analogLib/nport with s param file attached
schematic is just a schematic (metal resistors etc)
To run the test, I have assigned schematic_emx cellview in corner setup (and not the schematic cellview)
How have I run the test ?
I have created testbench schematic (in ADE assembler, right click on the test Netlist>Create... or Netlist>Recreate...), using the schematic cellview, not the schematic_emx cellview, which was successful
Then I have proceeded to run the simulation (using the schematic_emx cellview according to corner setup) and got netlist error, because the schematic_emx was not checked & saved
My question is - How can I define the Netlist>Create... (or Netlist>Recreate...) to create the netlist according to the corner setup?
Daniel
