  3. Bulk hierarchy path editing of 50 deepprobes, is it possible...
  • Subscribers 136
  • Views 405
Bulk hierarchy path editing of 50 deepprobes, is it possible at all within Virtuoso?
rod1
rod1 23 days ago
I got 70 deepprobes with paths like "path.to.block1.nodeN", where N=1,...70.
Now, I need to copy the same deepprobes and change all their paths to "path.to.block2.nodeN", where block2 is simply another instance of the cell instantiated by block1 as well, all nodes are equal.
Is there a way to do this without changing each deepprobe's path one by one? If somehow Virtuoso allowed VIM-style editing, this could be done in 5 seconds.
  • rod1
    rod1 23 days ago +1
    This procedure worked for me in the end. t_find and t_replace are strings. procedure(sge_replaceProbeNode(t_find t_replace) prog((cv win selObjs probes updated cdf p oldVal newVal) ; Validate that both…
  • rod1
    rod1 23 days ago
        ; Validate that both arguments are strings
        unless(stringp(t_find)
          error("sge_replaceProbeNode: argument 'find' must be a string, got: %L" t_find)
        unless(stringp(t_replace)
          error("sge_replaceProbeNode: argument 'replace' must be a string, got: %L" t_replace)
        probes  = list()
        updated = list()
        win = hiGetCurrentWindow()
        unless(win
          error("sge_replaceProbeNode: No active schematic window found.")
        cv = geGetEditCellView()
        unless(cv
          error("sge_replaceProbeNode: No editable cellview found.")
        selObjs = geGetSelSet(win)
        ; Filter to deepprobe instances only
        foreach(obj selObjs
          when(obj~>objType == "inst" && obj~>cellName == "deepprobe"
            probes = cons(obj probes)
        ; Remind user and exit if no deepprobes selected
        unless(probes
          warn("sge_replaceProbeNode: No deepprobe instances are currently selected. Please select at least one deepprobe and run again.")
          return()
        ; Apply replacement
        rexCompile(t_find)
        foreach(inst probes
          cdf = cdfGetInstCDF(inst)
          when(cdf
            p = cdfFindParamByName(cdf "probeNode")
            when(p && p~>value && rexMatchp(t_find p~>value)
              oldVal = p~>value
              newVal = rexReplace(oldVal t_replace 0)
              p~>value = newVal
              updated = cons(list(inst~>name oldVal newVal) updated)
        dbSave(cv)
        if(updated then
          printf("sge_replaceProbeNode: Updated %d deepprobe instance(s):\n" length(updated))
          foreach(entry updated
            printf("  %s: \"%s\" -> \"%s\"\n" car(entry) cadr(entry) caddr(entry))
        else
          warn("sge_replaceProbeNode: %d deepprobe(s) selected but none had \"%s\" in probeNode." length(probes) t_find)
        return(updated)
