  3. How to enable significant digit in virtuoso ADE explorer...
  • Subscribers 136
  • Views 191
How to enable significant digit in virtuoso ADE explorer.?
VIRAJ PANCHAL
VIRAJ PANCHAL 5 days ago
I want to show these result upto 6 decimal point. so how may I enable more significant digit in explorer.?
The below image show the result tab for explorer.
When I go particular tab then it shows the 6 decimal point in balloon box. I want that 6 decimal point in that tab, so how can I do that.?
    Andrew Beckett 5 days ago
    You can either go up to Assembler and use Options->Outputs Formatting, increase the number of digits, and then return to Explorer, or use:
    envSetVal("adexl.gui" "significantDigits" 'int 6)
    ;envSetVal("auCore.userPref" "printNotation"  'cyclic  "scientific") - or engineering or suffix
    The second is if you want to change the format options. There's a CCR 2233378 asking for this UI to be in Explorer too, but it hasn't happened yet (by all means contact customer support and ask for a duplicate to be filed on your behalf).
    Kind Regards,
  • VIRAJ PANCHAL
    VIRAJ PANCHAL 5 days ago in reply to Andrew Beckett
    Thanks Andrew. Its worked.
