  3. Sky130 PDK Not Visible in Cadence ASK Portal
  • Subscribers 136
  • Views 309
TG202608134354
TG202608134354 3 days ago
I was previously able to see the Sky130 PDK in the Cadence ASK Portal, but I can no longer find it. I'm not sure whether it has been removed, renamed, moved to a different location, or if this is an access-related issue.
Could someone please confirm if the Sky130 PDK is still available through the portal and, if so, where it can be accessed?
Thanks in advance for your help.
    Andrew Beckett 2 days ago in reply to TG202608134354 +2
    I don't have a rough ETA (the teams are off today and tomorrow for Thanksgiving), but the quote was "we are getting ready to post again" which implies it's soon. Of course, if this is just a PDK you…
    Andrew Beckett 3 days ago +1
    I'm checking to find out the reason (I have an idea, but rather than guessing I am asking the team responsible). Because of Thanksgiving holidays in the US, it may be a few days before I get an official…
    Andrew Beckett 2 days ago in reply to Andrew Beckett +1
    The reason is that there were several QA issues with the published version. There's a new version which fixes most of those issues and we're getting ready to re-publish it. If you need the old version…
    I'm checking to find out the reason (I have an idea, but rather than guessing I am asking the team responsible). Because of Thanksgiving holidays in the US, it may be a few days before I get an official answer.
    If you need the old version urgently, you should be able to contact customer support and request it (you can mention this forum thread), but I'd probably just recommend that you wait a short while for it to be added back with the fixed version (or using gpdk045 instead).
  • TG202608134354
    TG202608134354 2 days ago in reply to Andrew Beckett
    Thank you for the update. Do you have a rough ETA for when the updated Sky130 PDK is expected to be republished, assuming everything goes as planned?
  • KA202508261228
    KA202508261228 2 days ago in reply to TG202608134354
    I second this! I would love for an ETA, if possible. Meanwhile, I will reach out to customer support and see about getting an old-er version.
    Of course, if this is just a PDK you want to use for testing flows or building examples, I'd recommend using gpdk045 rather than the Skywater PDK. It's more mature and robust and has better coverage of using various Cadence flows. gpdk045 isn't a real technology, but if you're not going to manufacture anything that doesn't really matter...
    • Vote Up +2 Vote Down
  • TG202608134354
    Thank you, Andrew
