  3. display description about the commands executed.
  • Subscribers 152
  • Views 17090
ramya
ramya over 17 years ago
I would like to know how to disply description about the commands when executed in layout window. For Eg: when Copy command is executed,the message window should display the discription about the command like
info:copy
"select the figure to be copied"
"point the location to be copied."
the way it is displayed in prompt window.
  • skillUser
    skillUser over 17 years ago
    These prompts are part of the "enter function", for example, enterPoints() which has an argument ?prompts for supplying one or more prompts as you have noted.
    There are certainly some good examples of enter functions being used in SKILL code, one of which is the following solution on SourceLink:
    How can I created slotted metal paths?
     An alternative link to this code is in the CIC SKILL Code Library page: CCSslotMetal.il
    I hope that this helps you.
    Lawrence.
  • Austin CAD Guy
    Austin CAD Guy over 17 years ago
     If you are looking for the prompts to be displayed in the CIW (Command Interpreter Window), you must change your log file filter to include prompts. This is under the <Options><Log Filter> menu in the CIW.
    Ted
  • DK11
    DK11 over 5 years ago in reply to Austin CAD Guy
    thanks!
