  3. Can we draw mutlipath different width and spacing at the...
  • Replies 13
  • Subscribers 150
  • Views 23633
Can we draw mutlipath different width and spacing at the same time?
Manu81
Manu81 over 17 years ago
  • skillUser
    skillUser over 17 years ago
    Yes, with a multipart path the "offset sub paths" can certainly have different widths and separation from the master path.  Here is a brief section from the documentation on the rodCreatePath() SKILL function that you use to create a multi-part path:
    rodCreatePath(
            [?name              S_name]
            ?layer              txl_layer
            [?width             n_width]
            [?pts               l_pts]
            [?justification     S_justification]
            [?offset            n_offset]
            [?endType           S_endType]
            [?beginExt          n_beginExt]
            [?endExt            n_endExt]
            [?choppable         g_choppable]
            [?cvId              d_cvId]
            [?fromObj           Rl_fromObj]
            [?size              txf_size]
            [?startHandle       l_startHandle]
            [?endHandle         l_endHandle]
            [?prop              l_prop]
            [?offsetSubPath     l_offsetSubpathArgs...]
            ;l_offsetSubpathArgs Offset Subpath Arguments
            list(
                    list(
                            ?layer            txl_layer
                            [?width           n_width]
                            [?sep             n_sep]
                            [?beginOffset     n_beginOffset]
                            [?endOffset       n_endOffset]
                            [?prop            l_prop]
                            ;Repeat ROD Connectivity Arguments here
                            ) ;End of first offset subpath list
                    ) ;End of offset subpath lists
            ;End of l_offsetSubpathArgs
    ) ; end rodCreatePath
    => R_rodObj | nil
     I have included the arguments for the ?offsetSubPath keyword of rodCreatePath so that you can see how they are specified. It is a list of lists structure, each sublist refers to one offset sub path, but there can be multiple offset subpaths.
    I hope that this answers your question.
    Lawrence.
  • Manu81
    Thanks Lawerence, tere is one sample code given for shielding in Virtuoso® Relative Object Design User Guide. Will refer there too.Regards, Manu
  • Manu81
    this is what I have written...: ; create a shielded path
    procedure( shielded()
    cv=geGetEditCellView()
    errset(
    (let (cv layer purpose list_draw_layer tech width1 tfId)
    cv= geGetEditCellView()
    layer = car(leGetEntryLayer()) ;displays layer on LSW is taken
    purpose = cadr(leGetEntryLayer()); displays drawing or pin on the selected lsw
    list_draw_layer =list( layer purpose )
    tech = techGetTechFile(geGetWindowCellView()); rule deck file id is stored in tech
    width1 = techGetSpacingRule(tech "minWidth" layer) ; the minimum width is stored in width1
     rodCreatePath(
      ?name "shielded"
      ?layer list( layer purpose )
      ?pts list(2:-15 2:-5 15:-5 15:-5)
      ?width .12
      ?justification "center"
      ?cvId cv
      ?offsetSubPath
      list(list(
         list(
             ?justification "left"
             ?sep .16
             ?width .16
             ) ;end of offset sublist1
       list(
             ?justification "right"
             ?sep .16
             ?width .16
    ) ;end of offset sublist2
    ) ;end of offset list of lists
    ) ;end of rodCreatePath
    ) ; end of let
    t
    ) ; end of errset
    ) ; end of procedure
    what else needs to be done so that instead of the predefined values of metal layers and the width, spacing can be changed....
  • Manu81
    Hi Lawerence,
    Request you to please see the code:
    errset(
     rodCreatePath(
      ?name "shielded"
      ?width .12
      ?cvId cv
      ?offsetSubPath
      list(
         list(
             ?sep .16
             ?width .16
       list(
             ?sep .16
             ?width .16
    ) ; end of let
    t
    ) ; end of errset
    I want to take the values from the from the user. Therefore, I have created form and passing the values to the variables. Now, wrt to the above programme, can you please tell me what changes I need to make in order to have user defined width and spacing.
    Manu
  • dmay
    dmay over 17 years ago
    If you add two arguments to your procedure and use them in place of the .16 values in your rodCreatePath, then your form can call this command with the user's width and space.
    procedure( shielded(width space)
    ?sep space
    ?width width
    I hope this helps.
    Derek
  • rajput
    rajput over 12 years ago
     Hi Lawrence,
             Actually i want as many, master path for coaxial shielding required by user but using the rodCreatePath i am not able to do so.
    secondally my GND lines & Master path should not be of same width.so is there is any way to do this ???
    Regards
    pankaj
    You can only have a single master path, but there is nothing to stop you having one of the tracks as the master, and others (and the shield) as being offset sub-paths. Examples above show how to have different width for different offset subpaths.
    So I'm not sure what you can't do...
  • rajput
    Hi Andrew
       Actually i am writing script for coaxial shielding & i am shielding multiple paths at a time. suppose  five metal 2 paths to be coaxiallly shielded.then the gnd line of metal 2 lines should be sideways & for metal1 & metal3 it should be at top & bottom.
    1        i am using rodcreatepath to so. & i am using offsetSubPath for sideways & top & bottom metal layer to do so. But the problem i  am facing is how map top & bottom layer with middle layer as it is relative to  masterpath ..even i triedthe argument justification...
    2.  i have also used encSubPathfor top & bottom layers  & used enclosure argument but it is taking same enclosure all the sides which i dont want .please have a look on attached snapshot....
    I think this should do what you want (it would have helped if your picture showed what you want, rather than what you're getting, so I had to guess that this was indeed what you want). I've attached two pictures (merged together) showing the original multipart path at the bottom, and then after reshape and stretch. It has Metal1 on the bottom, Metal3 on the top, a strap of via1 and via2 on the gnd at the upper and lower edge, and then 4 tracks in the middle.
    cvId=geGetEditCellView()
    points=list(0:0 40:0)
    mainWidth=1
    mainSpacing=1
    gndWidth=2.0
    gndSpacing=1.5
    nTracks=4
    mainLayer="Metal2"
    bottomLayer="Metal1"
    topLayer="Metal3"
    viaLayer1="Via1"
    viaLayer2="Via2"
    viaWidth=0.5
    viaSpacing=0.5
    offsetPaths=nil
    for(i 1 nTracks-1
        offsetPaths=
            cons(
                list(
                    ?layer mainLayer
                    ?width mainWidth
                    ?sep -i*(mainWidth+mainSpacing)
                offsetPaths
    offsetPaths=constar(
        list(
            ?layer mainLayer
            ?width gndWidth
            ?sep mainWidth/2.0+gndSpacing+gndWidth/2.0
        list(
            ?layer mainLayer
            ?width gndWidth
            ?sep -(nTracks-1)*(mainWidth+mainSpacing)-mainWidth/2.0-gndSpacing-gndWidth/2.0
        offsetPaths
    subRects=foreach(mapcan viaLayer list(viaLayer1 viaLayer2)
        list(
            list(
                ?layer viaLayer1
                ?width viaWidth
                ?gap 'distribute
                ?space viaSpacing
                ?beginOffset -viaSpacing
                ?endOffset -viaSpacing
            list(
                ?layer viaLayer1
                ?width viaWidth
                ?gap 'distribute
                ?space viaSpacing
    topBotWidth=nTracks*(mainWidth+mainSpacing)-mainSpacing+(gndSpacing+gndWidth)*2
    topBotCent=gndWidth+gndSpacing+mainWidth/2.0-topBotWidth/2.0
    foreach(topBotLayer list(bottomLayer topLayer)
        offsetPaths=cons(
            list(
                ?layer topBotLayer
                ?width topBotWidth
                ?sep topBotCent
            offsetPaths
    rodCreatePath(
        ?cvId  cvId
        ?layer mainLayer
        ?width mainWidth
        ?pts points
        ?offsetSubPath offsetPaths
        ?subRect subRects
  • rajput
       Following is the script which i write for coaxial multipath it is working fine in gpdk180. Actually i want to make it technology independent .How can i do that. Actually i am new to skill learning from last 2-3  weeks .Please help me how to approach to make it technology independent..
    /***********Form Creation*************/
    procedure(openform()
    metal_list = list("Metal1" "Metal2" "Metal3" "Metal4" "Metal5" "Metal6")
    Sig_lines= hiCreateIntField(
    ?name 'Sig_lines
    ?prompt "No of Signal lines"
    ?value 1
    sig_metal_layer= hiCreateCyclicField(
    ?name  'sig_metal_layer
    ?prompt "Signal Metal layer"
    ?choices  metal_list
    spacing_lines= hiCreateFloatField(
    ?name 'spacing_lines
    ?prompt "Spacing b/w Signal lines"
    ?value 0.6
    width_lines= hiCreateFloatField(
    ?name 'width_lines
    ?prompt "Width of Signal lines"
    ?value 0.8
    spacing_gnd_lines= hiCreateFloatField(
    ?name 'spacing_gnd_lines
    ?prompt "Spacing from GND lines"
    ?value 1.0
    width_gnd_lines= hiCreateFloatField(
    ?name 'width_gnd_lines
    ?prompt "width of GND lines"
    ?value 1.2
    multipath= hiCreateAppForm(
    ?name 'multipath
    ?formTitle "coaxial_multipath"
    ?callback "enterpoints()"
    ?fields list(Sig_lines sig_metal_layer spacing_lines width_lines spacing_gnd_lines
    width_gnd_lines )
    ?help "multipath" )
     hiDisplayForm(multipath)
    procedure(enterpoints()
    enterPath(
       ?prompts list("Enter 1st point:" "Enter next point:")
       ?doneProc "Shield"
    ;; Create a shielded path
    procedure( Shield(win done pts)
      errset(
          unless( done printf("Finished!") )
          cv = geGetEditCellView()
         separation = multipath->spacing_gnd_lines->value + 1/2*(multipath->width_gnd_lines->value) +
         1/2*(multipath->width_lines->value)
         sig_lines=multipath->Sig_lines->value
         temp_list= list()
         i=1
         while(i<=sig_lines-1
         sepsiglines= i*(multipath->spacing_lines->value) + (i-1)*(multipath->width_lines->value)
                               lista=list(
                                      ?layer list(  "Metal2" "drawing" )
                                     ?sep sepsiglines
                                      ?width multipath->width_lines->value
        temp_list= append1(temp_list lista)
        i++
        if( sig_lines > 1
        then
        delta = sepsiglines + multipath->spacing_gnd_lines->value + multipath->width_lines->value
        if( sig_lines == 1
        then
        delta = separation
          rodCreatePath(
            ?layer        list(  "Metal2" "drawing")
            ?pts         foreach(   mapcar point pts
                             geWindowToEditPoint(hiGetCurrentWindow() point)
                 ?cvId         cv
             ?offsetSubPath
                         append(temp_list list(
                               list(
                                      ?sep separation
                                      ?width  multipath->width_gnd_lines->value
                               list(
                                     ?sep delta
                               list(
                                      ?layer list(  "Metal1" "drawing" )
                            ?sep  -((multipath->width_gnd_lines->value)+(multipath->width_lines->value)+(multipath->spacing_gnd_lines->value))
                                      ?width delta +2*(multipath->width_gnd_lines->value)+(multipath->width_lines->value)+(multipath->spacing_gnd_lines->value)
                               ) ;end of offset sublist3
                               list(
                                      ?layer list(  "Metal3" "drawing" )
                               ) ;end of offset sublist4
              ?subRect
                         list(
                             list(
                            ?layer     list("Via1" "drawing")
                            ?length     nil
                            ?choppable     t
                            ?sep     ((0.5*(multipath->width_gnd_lines->value))+(0.5*(multipath->width_lines->value))+(multipath->spacing_gnd_lines->value))
                            ?space     nil
                            ?beginOffset     -0.300000
                            ?endOffset     -0.300000
                            ?gap     "distribute"
                        );end of subRect list1a
                        list(
                            ?length     nil
                            ?choppable     t
                            ?sep     -(((sig_lines-1)*(multipath->spacing_lines->value))+(multipath->spacing_gnd_lines->value)+
                                                             (0.5*(multipath->width_gnd_lines->value))+((sig_lines-0.5)*(multipath->width_lines->value)))
                            ?space     nil
                            ?gap     "distribute"
                        );end of subRect list1b
                             list(
                            ?layer     list("Via2" "drawing")
                            ?length     nil
                            ?choppable     t
                            ?sep     ((0.5*(multipath->width_gnd_lines->value))+ (0.5*(multipath->width_lines->value))+(multipath->spacing_gnd_lines->value))
                            ?space     nil
                            ?gap     "distribute"
                        );end of subRect list2a
                                        list(
                            ?length     nil
                            ?choppable     t
                            ?space     nil
                            ?gap     "distribute"
                        );end of subRect list2b
                         );end of subrect of lists
       ) ; end of let
      ) ; end of errset
    ); end of procedure
    hiSetBindKey("Layout" "Shift<key>2" "openform()")
     Regards
    pankaj
