  3. skill code to change the direction of pin,and symbol of...
  • Subscribers 150
  • Views 4251
skill code to change the direction of pin,and symbol of that pin also
SUBBHAREDDY
SUBBHAREDDY over 17 years ago
Hi
 I want to change the direction of pin from input to inout pin,and at the same time i want to change the symbol
of that pin also in schematic view.
Pls write a sample code for the above requirement.
 Thanks and regards
Subbhareddy
    Andrew Beckett over 17 years ago
    term=dbFindTermByName(cvId "termName")
    term~>direction="inputOutput"
    master=dbOpenCellViewByType("basic" "iopin" "symbol")
    foreach(pin term~>pins
    pin~>fig~>master=master
    Note that in OA versions potentially you might need to update pin~>figs (rather than fig) but I don't think the schematic editor makes use of multiple pin figures yet.
  • Jack777
    Jack777 over 9 years ago
    I'd like to the same thing here, but on symbol pin. I followed your code, but stuck at "pin~>fig~>master=master", since there is not master properties. The code works fine on schematic.
    For symbol pins, these are not normally instances - they're just a shape. So it would be sufficient to do:
