  3. Skill code for Off Grid errors
  • Replies 22
  • Subscribers 153
  • Views 33762
kashvi
kashvi over 16 years ago
Do you have a skill code to clear the off grid errors on layout?
-Shiva
  • kbhow
    kbhow over 16 years ago
    Hi Kashvi,
    You can use Turbo Toolbox (TTB) to fix the off grid issues.
    TTB->Change Options->Fix Off Grid
    How
  • kashvi
     Thanks for the info. How!..Actually I have done with the Layout and some of the wires are on offgrid.
    instead of searching each one,  I want to move the layout itself on grid.
    -K
  • kbhow
    Hi Kashvi,
    It is the same. You can select all (bindkey: Ctrl-a ) and use the tool to fix grid for you. You not need to fix it one by one.
    Just let me know if you have other concern.
    How
  • kashvi
     Hi How,
    I'm not able to find TTB, I tried to display it with hiDisplayFixedMenu(Toolbox_Menu "left")..
    It says unbound variable
    Regds,
    -K
  • kbhow
    Hi Kashi,
    I believe u doesn't have Turbo Toolbox in your virtuoso. To solve the off grid issue, use the code below.
    ;; Process each selected object and fix the off grid issue
    procedure( howFixOffGrid(@optional (selset geGetSelSet()))
    foreach( obj selset()
    howPutObjOnGrid(obj car(howSnapGetGrids()) cadr(howSnapGetGrids()) 0 0)
    );foreach
    );proc
    ;; Get manufacturing grid from techFile
    procedure( howSnapGetGrids(@optional (cv geGetEditCellView()))
    let(( grids grid (dft list(0.001 0.001)) )
    if( cv then
    grid = techGetMfgGridResolution(techGetTechFile(cv))
    grids = list(grid grid)
    else
    grids = dft
    grids
    );let
    );proc
    ;; Process input obj to grid
    procedure( howPutObjOnGrid(obj @optional
    (gridX 0.001)
    (gridY 0.001)
    (offsetX 0.0)
    (offsetY 0.0))
    let(( changeFlag newPoints newObj)
    case( obj~>objType
    (("rect")
    when( (newPoints = _howPutObjOnGridGtPts( obj~>bBox gridX gridY offsetX offsetY ))
    obj~>bBox = newPoints
    changeFlag = t
    );when
    (("stdVia")
    when( (newPoints = _howPutObjOnGridGtPts( list(obj~>origin) gridX gridY offsetX offsetY ))
    obj~>origin = car(newPoints)
    changeFlag = t
    );when
    (("pathSeg" )
    when( (newPoints = _howPutObjOnGridGtPts( list(obj~>beginPt obj~>endPt) gridX gridY offsetX offsetY )) newObj = dbCreatePathSeg(obj~>cellView obj~>lpp car(newPoints) cadr(newPoints) obj~>width
    obj~>beginStyle obj~>endStyle)
    newObj~>net = obj~>net
    dbDeleteObject(obj)
    changeFlag = t
    );when
    (("path" "polygon" "layerBlockage")
    when( (newPoints = _howPutObjOnGridGtPts( obj~>points gridX gridY offsetX offsetY ))
    obj~>points = newPoints
    changeFlag = t
    (("inst" "label" "mosaic")
    when( (newPoints = _howPutObjOnGridGtPts( list(obj~>xy) gridX gridY offsetX offsetY ))
    obj~>xy = car(newPoints)
    changeFlag = t
    (("PRBoundary")
    dbSetBoundaryEdge(obj newPoints)
    changeFlag = t
    );case
    changeFlag
    );let
    );proc
    ;; Get new points
    procedure( _howPutObjOnGridGtPts( pts gridX gridY offsetX offsetY )
    let(( newListOfPts newPt changedFlag )
    foreach( pt pts
    if( (newPt = _howPutObjOnGridGtLoc( pt gridX gridY offsetX offsetY )) then
    newListOfPts = cons(newPt newListOfPts)
    changedFlag = t
    else
    newListOfPts = cons(pt newListOfPts)
    );if
    );foreach
    if( changedFlag then
    newListOfPts = reverse(newListOfPts)
    else
    newListOfPts = nil
    newListOfPts
    );let
    );proc
    ;; Get obj new point
    procedure( _howPutObjOnGridGtLoc( pt gridX gridY offsetX offsetY)
    let(( newPt (factor 10000.0) compFactor tempPt )
    ; Get compare factor with smaller tolerance up to 4 decimal points
    compFactor = 1 / factor
    if( zerop(offsetX) && zerop(offsetY) then
    newPt = _howPutObjOnGridRoundCor( pt gridX gridY compFactor )
    when( newPt == pt newPt = nil)
    else
    ; Substract offset before round up
    tempPt = list(car(pt)-offsetX cadr(pt)-offsetY)
    newPt = _howPutObjOnGridRoundCor( tempPt gridX gridY compFactor )
    newPt = list(car(newPt)+offsetX cadr(newPt)+offsetY)
    );if
    newPt
    );let
    );pro
    ;; Round coordinate
    procedure( _howPutObjOnGridRoundCor( point gridX gridY compFactor "gfff")
    let( (x y)
    x = round((xCoord(point) + compFactor) / gridX) * gridX
    y = round((yCoord(point) + compFactor) / gridY) * gridY
    list( x y )
    );let
    );proc
    How to use:
    1. Copy and load the script in CIW
    2. Select all object in your current cell view
    3. type command in ciw: howFixOffGrid()
    How
  • kashvi
     Hi How,
    Thanks for the code!..
    -K
  • Jifeng
    Jifeng over 16 years ago
    Hi, How.
    In using you script, I got the error message as follows:
    *Error* eval: undefined function -selset
    Is there anything wrong in my side? I load the file in CIW and it returns "t".
    Then I select all the shapes in the layout and type howFixOffGrid().
    Thanks!
    Jifeng
  • kbhow
    Hi JiFeng,
    The "selset" is a variable for selected object in cell view or user input. Please make sure u select object at the cell view, then go to CIW to execute the command. It should work.
    How
  • Jifeng
    Hi, How
    Thanks for the reply.
    I am sure I select the polygons in the layout view, but still got the same error message.
    But I found a similar script in the sourcelink and it works, ^_^.
    Jifeng
  • pmuppala
    pmuppala over 15 years ago
    Hey Jifang and How,
    I  am also getting the same problem even when i am selecting all the objects in the cellview.
    It says:  *Error* eval: undefined function -selset
    Hey Jifang, can u give me the script which u got , i searched in the sourcelink and could not find any luck.
    Any help is highly appreciated.
    Muppala
