  3. Skill code for Off Grid errors
  • Replies 22
  • Subscribers 152
  • Views 33221
kashvi
kashvi over 16 years ago
Do you have a skill code to clear the off grid errors on layout?
-Shiva
    The code has a mistake in it. Look at:
    procedure( howFixOffGrid(@optional (selset geGetSelSet()))
    foreach( obj selset()
      howPutObjOnGrid(obj car(howSnapGetGrids()) cadr(howSnapGetGrids()) 0 0)
    );foreach
    );proc
    The italicised part should not have parentheses - it should just be selset and not selset(). Note I did not test the code - I just spotted the deliberate mistake ;-)
    As for the Cadence Online Support equivalent code, try this: https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1Od0000000nWVlEAM&pageName=ArticleContent
  • pmuppala
    pmuppala over 15 years ago
    Hello Andrew, Thanks for your prompt response.This one worked to get rid-off the error i am getting ** Error** -eval -- undefined function selset.... But when i ran the script with the suggested modifications u told it still shows the off-grid errors. Regards, Muppala.
    Well, I'm not planning on fixing How's code (or checking it - sorry, don't have time at the moment) - I'd suggest using the code on Cadence Online Support as I know that's been used by many users.
  • pmuppala
    Andrew, Thanks for your time and reply. I will check it in the cadence online support forms. Regards, Muppala.
  • Jifeng
    Jifeng over 15 years ago
    Dear pmuppala:
    Sorry for my late response.
    There is a script online to fix the off grid error, but this only applies to polygons, not to cells;
    If you want to apply to cell, you need to flatten them, but still need to check the DRC errors after you use this script.
    For detailed usage, you can refer to the top of the file.
    Jifeng
    CCSputOnGrid.il
  • johnmck
    johnmck over 15 years ago
    I have used the code from Cadence Online Support but it seems to only work when I use dbCreatePolygon and not when I use rodCreatePath.  Am I missing something basic here?
    John
     John,
    You'd have to call the function on rodId~>dbId most likely (and if it's a multi-part path, you might have to do a rodUnNameShape() first so you could put any sub-objects on grid too). Alternatively you could adapt the code to be able to work on rod objects and adjust the point list of the rod object.
    You didn't say which function (or which solution) you were using, so I'm guessing a bit here.
  • johnmck
    Andrew, I did try the rodId~>dbId but it is a multi-part path (with some offsetSubPaths) and I didn't know about the rodUnNameShape().  Can I still get the dbId after I do a rodUnNameShape(
    I am using the putOnGrid() function.
    I should also warn you that I am trying to do this in a pcell, which seems to be giving more trouble than normal.
    John
  • johnmck
     I did find this link (sorry it's so long) that also really helped.
    http://support.cadence.com/wps/myportal/cos/COSHome/viewsolution/!ut/p/c5/dY1bboMwFAXX0gVY15iImE-DwTwUu6K8fxBJkYUSMGlC1bL6kgV0zufoaKCFfXP_Per-OZq5v0ENrdNZRPhWesCu8iXFMXVkmpUB3oHq9XA6_A8MQwPt8eUJsSh2RZh7OPbTOKFHm-DUgXI2X9NeyqGOLuaHG6Y54yxxi_T2briHlBIkllkoOJ2RdFCp9XTN1qbFZ-UPhS7QeqnqIHp2me2f7mupvMpd8OdZf5jsUbBf0sZYdVtno3u-CbEOS-PxJChkT8cH1avIA3QCGZlpgOU6byFlb39HbSTk/dl3/d3/L2dBISEvZ0FBIS9nQSEh/
     Hi John,
    BTW, the way I make the link cleaner is to use the "Email" link at the top of the solution - then you get a much more palatable URL - and you can miss off the search part at the end.
    To answer your previous question, you'd have to store the dbId and subParts in variables before doing the rodUnNameShape, because once it's no longer a rod object, there is no relationship between the ships.
