  3. Skill code for Off Grid errors
  • Replies 22
  • Subscribers 152
  • Views 33225
kashvi
kashvi over 16 years ago
Do you have a skill code to clear the off grid errors on layout?
-Shiva
  • FormerMember
    FormerMember over 14 years ago
    Could you please post here the mentioned code to correct off-grid errors? I'm unable to access this link.
    I'm using IC 6 version.
    Thanks.
  • johnmck
    johnmck over 14 years ago
    Here is the code from CCSputRodMppOnGrid.  I don't have a copy with all the disclaimers but to summarize, you should use this at your own risk.
    procedure(CCSputRodMppOnGrid(cv rodId)
    let( (shpIds compFactor path xgrid ygrid newpath obj1)
    xgrid = ygrid = 0.005
    ;compFactor = 1 / cv~>DBUPerUU
    compFactor = 0
    ;; Compile a list of all MPP shapes including the master path
    shpIds=cons(rodId~>dbId rodId~>subShapes)
    ;; Find out coordinates of all the existing MPP shapes
    foreach( obj shpIds
    case( obj~>objType
    (("rect")
    path = obj~>bBox
    path = list( lowerLeft(path)
    list(xCoord(upperRight(path)) yCoord(lowerLeft(path)))
    upperRight(path)
    list(xCoord(lowerLeft(path)) yCoord(upperRight(path))))
    ("path"
    /* In case of path create a dummy shape because don't want to modify the MPP shapes. And the code will be converting the path to polygon. */
    obj1=dbCopyFig(obj cv)
    obj1=dbConvertPathToPolygon(obj1)
    path=obj1~>path
    ("polygon"
    path = obj~>path
    ) ;case
    ;; newpath will store coordinates rounded to grid. Need to be reinitialized in every loop.
    newpath=nil
    ;; Round all the coordinates to grid
    foreach( pt path
    newpath=cons(roundCoord(pt xgrid ygrid compFactor) newpath)
    ) ;foreach
    ;; Create new shapes on the rounded coordinates
    path=newpath
    case( obj~>objType
    ("path"
    dbCreatePolygon(cv obj~>lpp path)
    dbDeleteObject(obj1)
    (("rect" "polygon")
    ) ;case
    ) ;foreach
    ;; Delete the ROD MPP
    dbDeleteObject(rodId~>dbId)
    t
    ) ;let
    ) ;proc
    procedure( roundCoord( point xgrid ygrid compFactor )
    let( (x y)
    x=round((xCoord(point) + compFactor) / xgrid) * xgrid
    y=round((yCoord(point) + compFactor) / ygrid) * ygrid
    list( x y )
    ) ;let
    ) ;procedure
