  3. perform SKILL functions in command line mode
  • Replies 16
  • Subscribers 154
  • Views 28737
cici
cici over 16 years ago
 Hi, I have a question on how to perform SKILL functions in command line mode. Can anyone help?
What I want to do is to
(1) start cadence with no GUI (I heard the -nog option but I cannot find any example)
(2) perform a series of SKILL function (defined in a do file) such as making a copy of cells in a given library
(3) quit cadence
 Thanks for your time and help!
  • kbhow
    kbhow over 16 years ago
    Hi cici,
    To run Virtuoso in no GUI mode, you can use "virtuoso -nograph " mode, so that it will run the virtuoso at the background. For your case, you need to create a replay file (eg: skillfunction.replay) which include all skill function that you wih to perform such as open cell view, copy, paste and etc in a single file. Please take note that, you must write exit at the end of the code in order for virtuoso to exit. Then invoke virtuoso in nograph mode together with the replay file, the virtuoso will execute the function in the replay file accordingly.
    Clear step by step
    1. Create a replay file with skill function ( function.replay)
            cv = dbOpenCellViewByType("Lib" "Cell" "View" "" "a")
     db
  • kbhow
    Hi cici,
    Clear step by step
     db
  • kbhow
    Hi cici,
    Clear step by step
     db
  • kbhow
    Hi Cici,
    Sorry i mis-click the 'Post' button before finishing my reply. =D
    Hi cici,
    Clear step by step
            dbSave(cv)
            exit ;This is important in order to close your virtuoso
    2. Invoke virtuoso in nograph mode with replay file
            virtuoso -nograph -replay function.replay
    3. Done
    How
    I tend to suggest using -restore rather than -replay as it is more like doing a load(), whereas replay is more like typing each command in the CIW. With interactive things there is a difference in behaviour with regards to whether functions are "blocking" or not.
    Best Regards,
  • jorenrefuerzo
    jorenrefuerzo over 13 years ago
    may i also ask more info about the -replay option in virtuoso?. or where can i get more informaiton?...
    i'm also looking for a way which is also to perform Skill function in command line...
    yuove mentioned that " replay is more like typing each command in the CIW" ..
    i tried this command :
                           "virtuoso -nograph -replay /lsc/projects/eda/jrefuerz/CAD/scripts/OpenLayout.il -log logko.log"
                               > this is to load the OpenLayout.il skill script that i made.. the second step is to type the function with argument... so basing from your desctiption of -replay.. i did this :
                                      "virtuoso -nograph -replay OpenLayout ( "mylib" "mycell" )"
    but this one doesnt work. the error says  "Badly placed()'s".
  • jorenrefuerzo
     is there anyone who can help?.. thanks...
  • TeeBro
    TeeBro over 13 years ago
    I believe the "-replay" commandline options argument is a file that contains the commands that you would type into the CIW.  So in your example you would have a file (lets say it's named commands.txt) that would contain:
    load("/lsc/projects/eda/jrefuerz/CAD/scripts/OpenLayout.il")
    OpenLayout("mylib" "mycell" )
    Then you would run virtuoso with the following commandline:
    virtuoso -nograph -replay commands.txt -log logko.log
    Indeed - giving commands on the command line directly is not what it does (I never said that). Personally I tend to use -replay for replaying CDS.log files, and use -restore for loading SKILL code (-restore is more like doing a load() in the CIW after starting).
  • jorenrefuerzo
    problem solved!!...
    thanks Teebro and Andrew for the help...
