  3. Metal co-ordinates of a PCELL
  • Views 15880
Vignesh054
Vignesh054 over 16 years ago
Is it possible to get the metal && poly co-rdinates of a Pcell without flattening the Pcell?
also is it possible to select a instance at a particular co-ordinate using Skill?
Vignesh T K
    Hi Vignesh,
    If you have the instance id, you can do:
    instId~>master~>shapes
    or
    instId~>master~>lpps
    to find each layer-purpose-pair, and then find the shapes on each layer. Having done that, you could use things like dbTransformPoint or dbTransformBBox to transform the coordinates to the top level coordinate system, passing instId~>transform as the transform argument.
    Essentially instId~>master is pointing at the subMaster of the pcell - i.e. the particular variant.
    To select something a fixed point use:
    point=20:79
    geAddSelectPoint(hiGetCurrentWindow() nil point)
  • Vignesh054
    //instId~>master~>lpps to find each layer-purpose-pair, and then find the shapes on each layer.//
    I did not get this.. Can you please brief on this?
    Vignesh T K
    Hi Vignesh,
    Something similar was discussed very recently. See this append by skillUser and my subsequent append.
    Come back again if it's still not clear after reading that.
    Best Regards,
  • Vignesh054
    Thanks  Andrew,
    It is working for me...
    Vignesh T K
