  3. layout instances name connected in a selected net.
  • Replies 9
  • Subscribers 150
  • Views 20193
marbs
marbs over 16 years ago
Hello All,
How to display all the layout instances name in CIW that is connected
in the selected net in layout  ?
 For example, if I select a net25 in the layout, in CIW, output will be,
net25 is connected in Q1-c , Q2b, Q3e .
Thanks in advance,
Marbs
  • Quek
    Quek over 16 years ago
    Hi Marbs
    If you are using IC614, a skillscript is actually not required. It can be done as follows:
    a. Switch to vls-XL mode
    b. In navigator, select a net and do a right mouse click
    c. In the mouse menu, go to "Select->All instances on net"
    d. The instances connected to the net will be highlighted in navigator and will also be selected in the layout
    Best regards
    Quek
  • Quek
    Hi Marbs
    If you are using IC614, you can find the instances on the net as follows:
    a. In navigator, right mouse click on the net
    b. Go to "Select->Instances on net"
    The instances will be highlighted in both navigator and layout. When posting questions, it would be good to state the version of Virtuoso which you are using:
    linux>icfb -W
    linux>virtuoso -W
    Best regards
    Quek
  • marbs
    Hi Quek,
    I am using Icfb version 5.10.41.500.5.109.  I am sorry for not specifying
    my icfb version. How to make a SKILL file to display all the instances name
    that is connected to a particular net in the layout ? for my version.
    Thanks in advance,
    Marbs
    Assuming you have a shape on the net selected, and the layout has connectivity information (eg was done with Virtuoso Layout XL), then:
    foreach(fig geGetSelSet()
    net=fig~>net
    when(net
    printf("net %s is connected to\n" net~>name)
    foreach(instTerm net~>instTerms
    printf("%s.%s " instTerm~>inst~>name instTerm~>name)
    printf("\n")
    Something like that. I didn't test it fully because I typed it on a mobile device.
  • marbs
    Thank you for the code, but what I want to display are only the layout instances name
    that are presently connected in the selected wires(M, SM, TM ), not all its complete
    connection as it is stated in schematic.
    For example:
    net 94 schematic connection is |Q23.B , |Q23.C , |Q24.B and |Q25.C
     but in my layout :
    net 94 is only connected to |Q23.B and |Q24.B
    If I select the wire in layout  presently connected to  |Q23.B and |Q24.B
    The output in CIW must be : The selected net net 94 is presently connected to |Q23.B and |Q24.B . Wire in layout
                                              not yet complete .
    I am sorry for  not clearing my first message.
    Please help.
    Marbs
     I'm afraid I don't know of a way of accessing this kind of information from Virtuoso Layout XL - it's known internally. In IC613/IC614 you could probably inspect the markers used by the annotation browser for showing incomplete nets, maybe.
    Otherwise you'd probably have to use some dbGetOverlaps() type function to see if the pin figures associated with the terminal associated with each instTerm on the net are covered by a shape which is on the same net. Even then, it wouldn't tell you whether there are gaps in the routing - in that case, how would you decide which are connected and which aren't?
  • strotta
    strotta over 7 years ago in reply to Andrew Beckett
    Hi Andrew!
    Is there any way to obtain the devices connected on a net from the schematic view?
    Andrew Beckett over 7 years ago in reply to strotta
    Please read the Forum Guidelines. You've asked a question in a 9 year old thread which is about layout instances, and you're asking about instances on a schematic. So that's at least two of the forum guidelines broken. I suggest you start a new post.
  • Marben
    Marben over 7 years ago in reply to strotta
    Hi Sttrotta,
    Something like these.
    Purpose       : Displays devices lists that are connected in a selected net or wire  in the schematic
                    and higlights all its connection. It can be use for tracing connections in schematic.
    Process       : Any process
    Environment   : VXL schematic editor , this skill file can also be run in VXL layout editor.
    How to run       : 1.Enter  in CIW. load("/home/marben/SKILL_VXL/net_selected.il")
                                 2.Select a portion of net or wire in the schematic window, then move the cursor in the
                                    CIW, then press 2 in the keyboard.
                                 3.All devices connected to that net will be automatically displayed in a text file,
                                    netConnection_layout.txt will be automatically created in user's VXl directory.
    Function Name : net_selected()
    Language      : SKILL
    Date created  : February 17, 2010
    Author        : Marben F. Orallo
    ;hiSetBindKey("Command Interpreter" "<Key>2" "net_selected() ")
    hiSetBindKey("Layout" "<Key>2" "net_selected()")
    hiSetBindKey("Schematics" "<Key>2" "net_selected()" )
    procedure(select_side()
                  net=fig~>net
          foreach(fig net~>figs geSelectFig(fig))
    procedure(net_selected()
    csh("touch ./netConnection_layout.txt")
        outPort = outfile("./netConnection_layout.txt")
                  net=fig~>net
                  when(net
                      printf("\n")
          fprintf(outPort "     Net %s schematic connection are :\n\n" net~>name )
          ;fprintf(outPort "net %s is connected to\n" net~>name)
                  net=fig~>net
                   when(net
                          fprintf(outPort "     Pin %s of instance name %s , cellname = %s \n"  instTerm~>name instTerm~>inst~>name instTerm~>inst~>cellName)
    ; start of outport
        fprintf(outPort "    \n\n\n        <<<------------------------------------------>>>" )
        fprintf(outPort "    \n\n               End of schematic net connection list . " )
        fprintf(outPort "    \n\n        <<<------------------------------------------>>>" )
       close( outPort)
        ;view("./netConnection_layout.txt" list(0:0 500:500) "SCHEMATIC NET CONNECTION")
        ; edit("./netConnection_layout.txt")
        ;hiRegTimer("system("open_net_selected")" 100)
        sleep(3)
        system("gedit netConnection_layout.txt &")
      ; End of outport
    select_side()
