  3. How to convert string to float
  • Replies 8
  • Views 25099
pdda
pdda over 16 years ago
I want to convert string to float.But this case is different from the other usuall convertion.
Here are details.
Example:
for( i 2 25
      parameters = cons(list( concat( 'w i    ) 'string  "3.0u"                               ) parameters)
Now .....i want to convert all w1 to w25 string elements to floats.
Can any help me onthis.....If you need any more information .......we can talk also.
K.srikumar
    For a start, w1 etc are symbols not strings. It's very unclear what you actually want to do - how would you convert w2 to a float?
    Please describe more clearly what you actually are trying to do. I can't figure it out, and I'd be surprised if others can.
  • pdda
    I am writing code for a pcell......i showed some part of the code.
    In the parameters part of the pcell code is defined like w2 to w25 as strings.I have to give the values in string(ex: "2.0u").But in the dody of the code all operations are done using w2 to w25 as float values(ex: 2.0).
    To link both of these i want to convert all strings  (w2.....w25) values to flaot values.
    K.srikumar.
    The bit you showed looks more like creating the argument to dbCreateParamInst(), rather than the pcell code itself. I'm assuming that you want to do this conversion in the underlying pcell code? If so, it would be something like:
    let((varName)
      for(i 2 25
        varName=concat('w i)
        set(varName cdfParseFloatString(symeval(varName)))
    Then any variables w2 through to w25 within the pcell code will have float equivalents of the strings passed in.
    Best Regards,
  • pdda
    I tried your thing ........it doesnt work.......so i split your steps into small steps  and then tried it.
    w1 is defined by using for loop.......using above what ever i sent a example.
    varName=concat('w 1)
    symeval(varName)
    cdfParseFloatString(symeval(varName))..............This command is failling
    K.srikumar.
  • pdda
    My main intension is........
    for( i 2 25
    ).............Here w2...w25 are strings
    after this.i want to use w2 ...w25 in the below line.
    Width =  get( cv~>parameters concat( 'w i ) ) - 2*cainwell
    But ........in the above line.........
    cainwell.........this variable is float and w1 .....w25 is string
    so i need convertion.......and i have to use it here.
    without convertion if i run it .......following error is comming
    *WARNING* ("difference" 0 t nil ("*Error* difference: can't handle (\"3u\" - 0.2)"))........
    K.srikumar.
    Well, if you will post irrelevant parts of your code, it's hardly surprising if you get responses that don't solve your problem.
    I'm still having to guess, and given that this is not an official support channel (it's just volunteers here, and others in the community that help out - I do this in my spare time - it's not part of my job), bear in mind that having to keep guessing reduces the likelihood that I'll answer your questions in future (sorry to be hard, but I have limited spare time).
    Most likely what you need is:
    Width =  cdfParseFloatString(get( cv~>parameters concat( 'w i ) )) - 2*cainwell
    but since you've not given enough of your code, it's hard to be sure. In your first paragraph, you say that w2 to w25 are strings. Well, they're not - presumably the pcell property called w2 to w25 is a string? It's really had to tell, because that is not normally how you retrieve pcell parameters within a pcell.
    Anyway, I'm not going to guess any more. Hopefully I got lucky.
  • pdda
    I can understand.....what you mean.
    But if i want to give you full code.......it is like some 600 line code and it calls so many other procedures.
    So, i thought .....instead of giving that much big code .........i given part of the code where is the problem.
    Yes , you are in right spot.
    But used it Width =  cdfParseFloatString(get( cv~>parameters concat( 'w i ) )) - 2*cainwell ...
    But it is not working.
    I think cdfParseFloatString is not converting it.
    K.srikumar.
  • pdda
    Thank you for your support..........
    I solved my problem ......by creating simple procedure.
    procedure( StrToNum(arg)
        if(eq(type(arg) 'string) then
           atof(arg)
        else
           sprintf(nil "%L" arg)
    and then i called the procedure
    Width =  StrToNum(get( cv~>parameters concat( 'w i ) )) - 2*cainwell
    I got this idea from your idea only........Thank you.
    K.srikumar.
